Am I Running Lean??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2011, 07:15 PM
prettyboyced's Avatar
i have a 350 l98 heads 270H cam 9.2:1 rpm intake 3.73 and 600 1405 edelbrock carb and i have a huge hestation at 3K it feels like there is no power there and timing is set at 36 total timing
View My Video
Old 01-28-2011, 08:30 PM
bigdog7373's Avatar
Of course it's fast
I would say so. Check simple things first like fuel filter, pressure, leaks somewhere, crushed hose or bent pipe.
Old 01-28-2011, 08:38 PM
ericnova72's Avatar
More for Less Racer
Sounds like one of two things. Either main metering is lean and or step-up springs are incorrect, or accelerator pump shot not big enough,... typical Edelbrock carb problems.
IIRC, Edelbrock 1405 is set up a bunch leaner on main jet and metering rods than the 1406 is. Take a look at the tuning info at Edelbrocks web site.
Old 01-28-2011, 11:45 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Actually, according to Edelbrock the 1406 is leaner than the 1405- by 2%.
The Owners Manual is HERE. With the info from it and from Edelbrock Performer Series Carburetor- Complete Guide to Set-Up, Tuning, and Performance Jetting, and for reference- Detailed Rebuild Instructions, you can go about adjusting it for better performance.
You might want to buy a Edelbrock p/n 1479 Carburetor Calibration Kit for your 1405 Performer carb.
If the carb isn't the problem, be sure the ignition advance curve is allowing full advance, and that there's not a "hitch" in the advance curve preventing the advance to increase right at the spot where the bog or lag is. It might take a lighter spring on one or both sides to bring in the advance sooner, if it doesn't detonate.
Old 01-29-2011, 01:28 PM
How rich should I go
am i running lean or just right? jak327 Engine 11 10-10-2010 08:52 AM
Running Lean...should I look for something else. Chevy Eleven Engine 2 08-28-2010 06:01 PM
Motor seems to be running a little lean 64 Impala SS 96 Engine 4 02-05-2008 06:08 PM
90 GMC 350... probably running lean etc etc wickedenvy Engine 8 08-20-2006 06:08 PM
running lean, need HELP BAD!!! 3dhunt Engine 3 11-28-2003 07:40 AM
