Am I seeing something? Disc brake isssue - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2011, 01:08 PM
Sir-x-Loin's Avatar
The kid is the man.
Hey all,
I have been unsatisfied with my rides brakeing ability since day one. I have a 57 chevy truck. sbc, 700r4, mustang2 power assist disc brakes up front and drum rear. I figured with that kind of set up, i'd go through the windshield when i stomped the brake. not so much.
I was looking at this snappy pic I took of my truck when I noticed that my caliper sits about 3:00. If memory searves me correctly, it should be closer to 1:30-2:00. Could this be aiding to my crumby brakeing?
[IMG][/IMG]
I have a few other brake threads out there too.
Thanks.
Old 07-22-2011, 01:35 PM
I do not think the caliper location will add or subtract to the efficiency of the brake power. It has more to do with bleeding. Disc brakes really do not lock up the tires, do not get me wrong you can get that, big rotors 6 pistons. You want more grip look at lager rotors and at least 4 piston.
One other little note you say ''mustang2 power assist disc'' calculate the weight difference between your truck and a mustang, that is a clue. Brake package sounds like it is not up to the job.
Old 07-22-2011, 01:41 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
I don't think the idea is to put your face into the windshield when you upgrade your brakes. I'm sure your overall stopping distance has greatly improved and with the fronts being discs, they're much less fade-prone. Also, remember that good stopping power relies on good tires too.
Old 07-22-2011, 01:52 PM
It doesn't.
Old 07-24-2011, 06:35 PM
Sir-x-Loin's Avatar
The kid is the man.
I based that statement on something I was told at tech school. I dont fully understand why caliper placement is vital, but the fact that ever assembly car has the caliper clocked at 1:30-2 viewed from drivers side.
Old 07-24-2011, 06:37 PM
Sir-x-Loin's Avatar
The kid is the man.
Scratch that. I think I'm wrong.
Old 07-24-2011, 06:40 PM
life is a temporary assignment
Your caliper are in the right place... And they are right about the location...It really doesn't make a difference where they are.... What size rotor's do you have up front ??
Old 07-24-2011, 07:15 PM
Good brakes are a function of the total package. If you are using the tiny MII rotors, you are not getting enough braking surface on the front where about 65% of your stopping power is generated on your pickup. Most MII kits have either GM 10 7/8" front rotors or Ford 11" rotors on the front. If you have either of those on the front, you should have a matching (balanced) master cylinder that is for a disc-drum set up. You also want to make sure the plumbing is not crossed up ie, feeding the front from the chamber designed for the rear. And last, if the MC is under the floor, you will need the appropriate residual valves installed. Not having the valves installed usually results in a poor pedal or pumping action to get a pedal, but also can cause poor braking on the front.
Old 07-25-2011, 04:42 AM
I'm afraid you are. New cars have calipers anywhere from 9:00 to 3:00.
Old 07-25-2011, 08:11 AM
It is all about bleeding the brakes, that is it in a nut shell. Schools are not real life, close bit no cigars.
Help with 68 camaro emergency brake install disc brake jdp2603 Suspension - Brakes - Steering 4 02-13-2010 07:56 AM
Will a Brake Master Cyl. Designed for Disc/Drum be Adequate for 4-Wheel Disc Brakes? mrwumper Suspension - Brakes - Steering 3 04-16-2009 09:38 AM
brake line help with a disc brake conversion novagirl74 Suspension - Brakes - Steering 3 04-01-2009 08:20 PM
65 GTO Disc brake kit jhenry Suspension - Brakes - Steering 3 02-04-2006 09:17 PM
Mecanical disc brake caliper for parking brake? bigun Suspension - Brakes - Steering 4 12-15-2005 08:43 PM
