am I wrong or not - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2009, 07:30 PM
am I wrong or not
Took vette to local alignment shop knew something was not right when the oldest one there working on cars looked about 17 y/o After about 3 minuets on the rack and a 5 foot pry bar was told that all 4 ball joints and idler arm were completely shot and was given a estimate for almost $800.00 for them to replace parts to be able to do the alignment.
I may not be the sharpest knife in the drawer but have worked on cars an rods all my teen and adult life and can't never remember ever having to replace upper ball joints from being wore out. Vette only has 40000 miles on it. Do I change all 4 or are they just trying to sell parts and labor. or just find a new shop What do you guys think?
Old 06-28-2009, 07:36 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Try another shop if you are not satisfied with what this one has told you. JMO .Cole
Old 06-28-2009, 07:40 PM
Last journal entry: frame build
I'd be looking for a different shop. Didn't say what year vette, but even the ones that had greasable joints would last much longer than that with no grease. If it really had all those problems, it would hardly be drivable.
Old 06-28-2009, 08:10 PM
thanks guys its a 1979 corvette and yes it has the greesable joints just needede to know that i was not wrong about the shop been driving the car some when weather permits i had just rebuilt the steering system on it and wanted to get the alignment checked out
Old 06-28-2009, 08:23 PM
Wiki Edits: 31
if your uppers were bad they would most likely be knocking.... I did have an upper go bad on my '98 Ranger, but it happens with them.. only vehicle I'v ever had go on me..
the allignment shop I use, sort of specializes in the older Corvette suspensions.. other allignment shops in the area send them to him because they can't get it right.. 1 man show, $60 an allignment, not a bad deal being I know he's the best in the area.. I used to do allignments but.. not my thing , altho there easy jobs usually
Old 06-28-2009, 08:31 PM
thanks matt i am going to replace the lower ones there cheep and easy to get and will give me some peace of mind . after 3 years a few more hours and a few more dollars cant hurt to much. I have replaced upper joints after they have been broken or from grease worms getting into them but just have never seen one just wear out and go bad. I guess with a 5 foot prybar you can get anything to show some movement
Old 06-29-2009, 08:39 AM
302 Z28's Avatar
98 Ford Ranger does not have ball joints, they have king pins.
Vince
Old 06-29-2009, 01:37 PM
streetrodderbn's Avatar
Certifiable Streetrodder
What's a "grease worm" ?!!
Old 06-29-2009, 02:34 PM
Yeah. What IS a grease worm?
Old 06-29-2009, 02:57 PM
Wiki Edits: 31
Vince
sure they do... '83-'97's use twin I beams and king pins like the F-150's, but '98+ uses upper and lower balljoints in a basic SLA suspension... replacing upper balljoints require removal of the upper control arm, which is a pain
Old 06-29-2009, 03:58 PM
grease worms are what we told customers had got in u-joints, ball joints wheel barrings and ate all the grease. was better then telling them it was lack of care and maintenance that was the cause of failure
Old 06-29-2009, 04:04 PM
prostreet6t9's Avatar
Differential/Driveline
I would get another opinion. Depending on where you took it,some of the Franchise places have questionable selling practices. Some of the Tech's are paid a bonus for stuff they find wrong and tend to try and sell services that are not needed.
Old 06-29-2009, 04:08 PM
T-bucket23's Avatar
Wiki Edits: 26
It is very possible all 4 ball joints are no good. A lot of them had some sort of non metalic parts internally and they can go bad with age. It is something you need to take somewhere and have checked before you change anything. You may be wasting $ changing the lowers if they don't need changing.
Alignment shops make their money changing front end parts and some pay commission to the "techs" for selling parts. That $600 job probably has a raw cost of $200 so it is much more profitable than a $79 dollar alignment.
Chet
Old 06-29-2009, 04:26 PM
took car over to a different shop after checking it out was told lower left ball joint showed some wear but was not to bad for a alignment if i wanted to change it out they would check alignment and reset it for me no charge. checked on parts i can get the lower ball joints at local parts store for $19 each. only about 1 1/2 hours to change out. will just change them both out and take it back for a check.
Old 06-29-2009, 04:28 PM
T-bucket23's Avatar
Wiki Edits: 26
I wouldnt put $19 ball joints in my car. Check the price on Moog joints. They are still fairly decent quality and are readily available.
Chet
32 Ford rear axle setback; wrong info? F&J General Rodding Tech 17 07-04-2008 07:40 AM
Look at my combo and tell me whats wrong 1985fiero Engine 8 06-24-2004 11:45 PM
Grrr- What am I doing wrong... Beenaway2long Hotrodders' Lounge 3 05-21-2004 07:46 AM
Whats Wrong With Website?!? 87442lover Hotrodders' Lounge 1 05-12-2004 07:04 PM
what the heck is wrong? Joe_Alan216 Engine 10 07-16-2002 01:28 PM
