-   -   amador1 (http://www.hotrodders.com/forum/amador1-11712.html)
amador1 02-13-2002 04:31 PM
amador1
Hi gang, I need to upgrade my ford 9in. drum brakes (small bolt pattern-68 t bird) to disc brakes. Have factory disc up front and need info as to what will adapt - new or bone yard parts and what size disc. would be recommended . Thanks all---George
PAULWELDIT 02-14-2002 09:15 PM
I know you'all are going to holler, but a company named STREETROD MANUFACTURING makes some inexpesive brackes for almost every rear end, that use GM calipers.If you want a parking brake (a must in Tx. for inspection sticker)you use the rear calipers from an Olds Toronado or Riviera--if not you use the frt. calipers, which you can get over the counter loaded or from the" bone yard".SPEEDWAY may also carry these kits.
