Amazing new discovery! - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Off-Topic
Old 11-09-2007, 04:49 PM
coldknock's Avatar
I have discovered that the amount of horsepower gained from a pocket port and three angle valve job on a 2.3L Ford is precisely the amount of horsepower you lose by not disconnecting the vacuum line before you set the timing when you put it back together!
It was a dead brain moment.
I thought my efforts were in vain until I remembered that I never reconnected the vacuum line, and discovered that I never disconnected it to begin with.
Larry
Old 11-09-2007, 04:51 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
ha ha, awesome. I used to have one of those motors. Not a bad little mill but no guts at all!
K
Old 11-09-2007, 04:55 PM
coldknock's Avatar
I have since used the butt-dyno to affirm that the Offenhauser dual port intake and Hedman hedder are worth plenty of grunt.
Tuning a 4 barrel carb on a 4 cylinder engine is another chapter to itself.
Larry
Old 11-10-2007, 07:03 AM
Wiki Edits: 3
Dude I can't believe you are wasting your time with that stuff! You're the last guy I would have thought would be messing with a four-popper!
How have you been anyway?
K
Old 11-10-2007, 09:39 AM
coldknock's Avatar
It's all about the MPG, dude.
I'm attempting to get more work done with the same amount of fuel. That way I get another few miles out of a gallon of the liquid gold. Right now the cranking cylinder pressure is just a tick under 200psi and the temp's hovering near 170. I was able to drop the total timing to 29 degrees with better combustion chambers and a tight quench. Less negative work ya know. All this being conducive to getting more work done, horsepower/torque, without using any more fuel.
I'd like to play with the cam timing but roller cams are $$$$$. For now I'll work with what I have. the next step is heated fuel and water/alcohol injection.
By the way, I haven't abandoned real horsepower. I'm just making other peoples cars faster. It's less expensive and I still get to play.
Larry
Gas Monkey update: Discovery drops Rawlings Jon Off-Topic 140 11-18-2012 11:50 PM
Amazing Discovery about Ford F1 Gauges. lakota Hotrodding Basics 6 12-19-2007 12:44 AM
great news -- Discovery is backing down! Jon Hotrodders' Lounge 37 08-24-2007 05:28 PM
Discovery demands takedown of SpankMaker on SpankMyMarketer.com Jon Hotrodders' Lounge 34 02-28-2007 04:29 PM
