amc 327 intake question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2007, 09:02 PM
to anyone that can help. i have a 1964 amc rambler Ambassador with a 327 engine. it is a stock two barrel intake and i want to upgrade to a 4 barrel. does any one know how i can get hold of a four barrel intake. thank u for ur time
Old 12-11-2007, 09:49 PM
woodz428's Avatar
Troll Hunter
You have very few options. That engine shares nothing in common with the later engines which had many speed parts available. 2 options would be to find a Rambler specialist that may have an original intake, check the speed part section of Hemmings, there are several shops that deal in antiquated/obsolete intakes. If they don't have one they will attempt to locate one. Finally, I believe it has and old style intake and a separate vallet cover. This lends itself to some easy fabrication by anyone that can work aluminum and weld it.
Old 12-21-2007, 05:58 PM
One on ebay, possibly salvaged from the titanic judging from the rust, nothing sand blasting cant fix.
http://cgi.ebay.com/ebaymotors/Stock...spagenameZWDVW
noob question intake cam shaft kit RAUL78 Engine 1 08-11-2006 08:10 AM
327 question? terrywolfpack Engine 10 07-04-2006 03:35 AM
1965 Impala 327 Timing Question EazyDuzIt102 Engine 2 06-25-2004 03:07 AM
65 Impala 327 Distributor Question EazyDuzIt102 Engine 0 06-24-2004 10:28 PM
"Dry" Intake Manifold Question bluesman123 Engine 4 02-11-2004 12:12 PM
