I have a beat up geo metro. the three banger was burnt to hell. but i do have an amc 360 with 401 heads that fits. i cut out the center of the fire wall and pulled the old motor and trans. I have a rear end from a chevy luv which fits under the metro. a power glide is sitting shotgun with a home made drive shaft.
i don't know how i will steer the damn thing. the old column is there but the motor blocks the linkages. any tips out there? they dont have to make sense as long as i can jerry-rig it. [ February 22, 2003: Message edited by: 73 Nova Guy ]</p> |
sorry, in a small white town... i'll take notice-justin
seriously though.. i have a lot of hours invested.
i would like to get this thing on the road while the tags are current!
just in case this is a politicaly correct site
non power steering just suspension with wheels attached right now very low to the ground with all the weight |
so far the motor and fuel supply are not united.
the engine is at near center the front is bout on the ground i was thinking gasser style solid front axel on leaf springs but i dunno i have a fuel cell from a boat i am going to use the old tank was replaced with an axel! it is a 76 amc and i still havent solved the "how the hell do i start it problem! |
i just need to figure out some steering . otherwise it stays on blocks. it (motor)runs and has bakes. just no steering . i also am converting a 3/4 ton dodge van into a dune buggy.
cool man. it'll be safe (marginaly) but real quik. as long as i dont turn too fast and roll. if i can make it look semi stock the po won't catch on . unless they lift the hood or see rear wheel burn outs! i'll just have to see if anyone else responds. thanks anyway steve. -justin
Hey Nova.
It will fit, but you will have to check for header or manifold clearance's. The glide will require an adaptor and you will need to srtiffin up the springs. Just a matter of measuring and thinking. HG P.S. Whats the diff in Jerry riggin as compared to Jimmy riggin. Both normal names??? |
Hemmie, it wasn't "jerry riggin'" before, just open up your theosourusisisisis...and look for ignorant its the "N" word
If I had a brain I'd be dangerous! I'm honestly not feeling the love for this '92 metro prodject. If you like it go for it, but I don't think I would want to ride in it. It would be like riding in a big figure ice skate. You know those skates that you get going at a good rate on the first glide then you bring the other foot around and do a faceplant because you hit the studs on the front of the blade. Those cars aren't built for that kind of stress. My bro's wife had a little red one and she hit a curb (6-7") trying to dodge a kid and the front end peeled off like the top on a tuna can. If your up for the work, got for it and hope you get it done, just work me when you go out in it because I'm staying home HK [ February 22, 2003: Message edited by: Halloweenking ]</p> |
Well got the adapter
trying to stiffen frame locating stronger front suspension still can't steer the dang thing. and yeah, hemmie, i did say something a little different than "jimmie" and "jerry thanks for helping here hemmie, any idea how to make it steer? I got no clue, maybe a solid front axel but it doesnt sound safe |
| Recent Hotrodders' Lounge posts with photos |
