AMC 360 dies at wot - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2017, 05:17 AM
UngerMarkus's Avatar
TuckīnīRoller
AMC 360 dies at wot
Hi guys!
I have a strange problem with my Wagoneer. Itīs powered by an AMC 360 with a brand new Street Demon carb and a HEI dizzy.
It starts and idles great. Also it performs well cruising around and under light acceleration. But as soon as you floor the pedal it cutīs out. No matter what speed.
No backfire. The engine just stutters. When you stay on the gas long enough, it dies.
Things I did so far:
Voltage on distributor is 12,6V regardless of RPM. (Transmission in Park)
I cleaned the carb (although itīs new). No improvement.
I installed an A/F-ratio monitor. It reads 12,5-13,5 at any load situation.
Vaccum gauge reads 18'' hg at idle. Reads very low when stutter occurs.
I checked for vacuum leaks with brake cleaner, but could not find any. All vaccuum lines seem to be ok.
I tightened the secondary air flap down. No improvement.
Any ideas?
Thanks
Old 04-21-2017, 07:46 AM
RWENUTS's Avatar
What's your initial timing?
Old 04-21-2017, 08:16 AM
Plugged fuel filter? Rubber or hard-line gas line? If older rubber, sometimes they will collapse, or deteriorate & constrict.
Old 04-21-2017, 10:11 AM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
I had a similar but not as severe situation with my Pontiac. Chinese coil in cheap new HEI was the cause. Mine is coil-in-cap. If yours is and the coil says "Made in China" on top, I'd try another "known good" coil and pitch that one over the fence.
Old 04-21-2017, 01:25 PM
techinspector1's Avatar
Wiki Edits: 326
Are you using a vented gas cap or is there some other way for the fuel system not to pull a vacuum.
Is there any rubber fuel line in the system? Pump gas has ethanol in it, which will disintegrate rubber. I have heard of pieces forming a flap inside the line and blocking off the passage of fuel.
Old 04-21-2017, 02:44 PM
Cars, Trucks, Boats
Vacuum gauge reads 18'' hg at idle. Reads very low when stutter occurs.
This is a stock, high vacuum engine? May need to tighten the secondaries air door down some more to prevent secondaries opening at too low an RPMs...
What happens if you rev up gently to about 3,500 RPMs in 2nd gear and then floor it?
Do you have a tach?
In other matters, what CFM is the carb.? Smaller ones really open the secondaries too soon because of high vacuum in the primaries...
Single or dual plane intake? Single planes usually require richer secondaries jetting... About #66 primary jets for a 360" size engine... secondary jetting depends on number of power valves, single/dual plane, etc...
Would like to see voltage around 13's at distributor with engine running... 14 at battery... mid 12's battery engine off... low 12's distributor with engine off... Did you replace a points distributor with an HEI and not bypass the ballast resistor?
A/F 12.5 - 13 at WOT... 15's while cruising steady speed...
About 12 degrees idle ignition timing (vac advance disconnect and hose plugged) and up to about 36 - 40 max advance at 2500 - 3500 RPMs...
Old 04-21-2017, 07:04 PM
Cars, Trucks, Boats
Forget the numbers I mentioned on jet sizes... Demon carb.s use a jet and rod arrangement like a Q-Jet carb., not a Holley...
Comparing the Street Demon with a Traditional Holley Carb
AMC 360 rebuild monzter Engine 6 05-16-2013 06:56 PM
AMC 360 v8 jim martin Hotrodding Basics 1 12-16-2010 10:57 AM
go to WOT eng dies/let up and engine runs again! dvdkramer Engine 15 03-19-2010 07:31 PM
amc 360 fullof questions Engine 6 09-05-2008 04:55 PM
AMC 360 in a '92 metro? 73 Nova Guy Hotrodders' Lounge 35 02-26-2003 11:23 PM
