Amc 360 motor problems. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2013, 11:47 AM
Car ran fine went to put gas in it. Went up over a hill got on it a little bit. Motor popped through the carb. Wont start now? HELp
Old 04-07-2013, 11:51 AM
vinniekq2's Avatar
fuel/compression/spark?
Old 04-07-2013, 12:10 PM
bondo's Avatar
Ayuh,... Welcome Aboard,...
Generally speakin' in my experience, poppin' through the carb is caused by a Lean condition,...
Could be crap in the tank, bad fuel lines, a dyin' fuel pump, or just plain ole Crud in the carb...
Checkin', 'n changin' any, 'n all the fuel Filters will give ya a handle on exactly Where the issue might be,...
'n like vinniekq2 says, ya need fuel, fire, compression, 'n All at the Right Time for any motor to Run,...
You'll have to check, 'n see which 1 of the 4 yer missin'....
The Following User Says Thank You to bondo For This Useful Post:
blash (04-07-2013)
Old 04-07-2013, 01:54 PM
T-bucket23's Avatar
Wiki Edits: 26
Those love to pop timing chains. See if it is anywhere near close to being it time. Pull the distributor cap and crank it, see if the rotor is turning
Chet
The Following User Says Thank You to T-bucket23 For This Useful Post:
blash (04-07-2013)
Old 04-07-2013, 02:15 PM
poncho62's Avatar
Wiki Edits: 5
My first thought was timing chain.
Old 04-07-2013, 03:16 PM
LATECH's Avatar
Originally Posted by poncho62 View Post
my first thought was timing chain.
x 3 ............
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
blash (04-07-2013)
Amc 360 motor problems. blash Engine 2 04-07-2013 12:10 PM
AMC 360 v8 jim martin Hotrodding Basics 1 12-16-2010 11:57 AM
AMC 360 starting problems... jevonniespapi Engine 18 11-18-2010 12:24 PM
amc 360 fullof questions Engine 6 09-05-2008 05:55 PM
AMC 360 in a '92 metro? 73 Nova Guy Hotrodders' Lounge 35 02-27-2003 12:23 AM
