AMC 360 v8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2010, 10:42 AM
AMC 360 v8
I have a 68 AMX , was a 343 4 speed car. I am putting a 360 in it. can someone please tell me where the block id code are on this engine . It is stamped 360 on the block. I know 70-71 are different then the 72 and up
Old 12-16-2010, 10:57 AM
Wiki Edits: 31
I do not belive there is a block ID other than the 360.. there diffrent at the crankshaft because of the switch from BW automatics to Chrysler TF's.. and it should look like the 343 crank at the rear, but being a 4spd the switchover may not be that bad. I think they can be adapted to the manuals ither way with the correct bellhousing... I'm sure people on www.theamcforum.com know for sure
Need Help Dialing in on a build, AMC 360 fifesjeep Hotrodding Basics 15 03-31-2009 05:14 PM
Best V8 for 1969 AMC Rambler? 1983lux Engine 15 12-08-2008 09:43 AM
Camaro V6 to V8.. anyone ever done it? C10 Engine 3 11-23-2007 12:12 PM
heads mike huckfeldt Engine 13 01-27-2007 08:11 PM
AMC V8 Casting Numbers petiepye Engine 7 02-15-2006 09:10 PM
