-   -   AMC Pacer IFS experts come in here please!!!!!! (http://www.hotrodders.com/forum/amc-pacer-ifs-experts-come-here-please-190308.html)
paintman27 01-07-2011 12:17 PM
Hey guys,newbie here with my first post! I am curently working on a small project with an AMC Pacer front end. After spending some time reading some of the threads here I noticed some of you guys have the same front end. I was hoping you could point me in the right direction as to where is the best place to find parts. I have been able to obtain a complete front end rebuild kit from Kantner Restorations. However I would also like to rebuild the calipers and replace the discs. I would also like to either replace or have the rack rebuilt. from what I have read, there is some interchangability between Ford, GM and Pacer. Is this true? If so what make and year would I ask for when oredering new parts? I would love to hear your solutions. Thanx guys I really apreciate your help. And please don't just say put a Mustang II in it.
matt167 01-07-2011 01:24 PM
the rack is the biggest issue with the Pacer front. it is no longer available. most everything else still is. and you might even find a diffrent rack that may work, but it won't be a bolt in.. if your rack works like it should, don't worry about it...
59ramblersuper6 03-27-2011 07:54 PM
AMC Pacer parts
I was just on Autozone.com and they have alot of available parts listed for the Pacer frontend. Including a new manual Rack for 143.00 + 14.00 for a core charge!!! so according too that they are available. If not then checkout Blazer Auto or American Parts Depot.
fwinter01 10-05-2011 07:12 PM
pacer front rotors
have a complete set of old rocket 5 spokes mags, rear end or third member is a gm 10 bolt mags fit fine, would love to use same mags on front. wondering what gm front rotors would interchange with pacer spindles. building a 46 chevy pickup with a new 305 crate with turbo 350. power rack will require rebuilding
farna 12-14-2011 04:31 PM
No GM rotors will interchange. You can take the Pacer rotors to a machine shop and they should be able to press the old studs out and drill the GM pattern between the old one, then press in new studs. I wouldn't try this myself -- the pattern must be perfectly concentric.
fwinter01 01-01-2013 05:57 PM
power steering pump for a pacer power rackinpinion
curious if a gm power steering pump will work fine with a 1978 pacer pwr steering rack, any help would be great
