AMC Pacer IFS experts come in here please!!!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2011, 01:17 PM
Hey guys,newbie here with my first post! I am curently working on a small project with an AMC Pacer front end. After spending some time reading some of the threads here I noticed some of you guys have the same front end. I was hoping you could point me in the right direction as to where is the best place to find parts. I have been able to obtain a complete front end rebuild kit from Kantner Restorations. However I would also like to rebuild the calipers and replace the discs. I would also like to either replace or have the rack rebuilt. from what I have read, there is some interchangability between Ford, GM and Pacer. Is this true? If so what make and year would I ask for when oredering new parts? I would love to hear your solutions. Thanx guys I really apreciate your help. And please don't just say put a Mustang II in it.
Old 01-07-2011, 02:24 PM
Wiki Edits: 31
the rack is the biggest issue with the Pacer front. it is no longer available. most everything else still is. and you might even find a diffrent rack that may work, but it won't be a bolt in.. if your rack works like it should, don't worry about it...
Old 03-27-2011, 08:54 PM
AMC Pacer parts
I was just on Autozone.com and they have alot of available parts listed for the Pacer frontend. Including a new manual Rack for 143.00 + 14.00 for a core charge!!! so according too that they are available. If not then checkout Blazer Auto or American Parts Depot.
Old 10-05-2011, 08:12 PM
pacer front rotors
have a complete set of old rocket 5 spokes mags, rear end or third member is a gm 10 bolt mags fit fine, would love to use same mags on front. wondering what gm front rotors would interchange with pacer spindles. building a 46 chevy pickup with a new 305 crate with turbo 350. power rack will require rebuilding
Old 12-14-2011, 05:31 PM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
No GM rotors will interchange. You can take the Pacer rotors to a machine shop and they should be able to press the old studs out and drill the GM pattern between the old one, then press in new studs. I wouldn't try this myself -- the pattern must be perfectly concentric.
The Following User Says Thank You to farna For This Useful Post:
fwinter01 (01-01-2013)
Old 01-01-2013, 06:57 PM
power steering pump for a pacer power rackinpinion
curious if a gm power steering pump will work fine with a 1978 pacer pwr steering rack, any help would be great
Hood latch 1978 pacer Steve Martin Body - Exterior 5 03-20-2009 10:19 PM
pacer front swap 56 dream truck Suspension - Brakes - Steering 7 04-30-2008 08:28 AM
new member ( Rambler 401 ci & Pacer 500 ci) cadipacer Introduce Yourself 1 11-08-2005 09:40 PM
Pacer Ball joints hatetank Suspension - Brakes - Steering 1 08-28-2003 08:06 AM
Edsel Pacer hot_rod_kid Hotrodders' Lounge 2 11-24-2002 08:20 PM
