AMC Valve Lash Adj - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2012, 12:12 PM
AMC Valve Lash Adj
Greetings, I have a question regarding valve lash adjustment on a AMC 401 Tuff Dawg engine. I have about ninety minutes run time on motor and was thinking about when would be a good time to check adjustment and process of checking/adjusting valves. This being a performance engine is there a specific gap to shoot for. Thanks
Old 12-31-2012, 12:29 PM
techinspector1's Avatar
Wiki Edits: 326
Why do I get the feeling that this is a plug for Tuff Dawg rebuilders?
Old 12-31-2012, 12:40 PM
vinniekq2's Avatar
Im guessing a solid cam? New engines get a full visual check/fluid check,leak check first time its shut down.
Fill up fluids,make notes, drive a few minutes,recheck any flaws noted from first check,repeat until no changes noted or repairs made.
Drive it up and down the RPM range a few times,first time 1/2 throttle, then a couple full throttle pulls,10% below red line.
recheck,listen,look.
Im ready to race
Old 12-31-2012, 12:52 PM
Valve adjustment
I bought engine from guy who was going to put into a 77AMX but he passed away and I'm finishing up where he left off. The dust ment I was wondering about is valve adjustment. Thanks
Old 12-31-2012, 01:14 PM
Wiki Edits: 326
Google Tuff Dawg. Their phone number should be on their site. Call them and ask your questions.
77 amx
valve adj skipp General Rodding Tech 5 11-23-2012 07:07 AM
300ci in-line six(valve lash&timming adj.) bonnen1962 Engine 2 06-25-2009 05:27 PM
adj. modulater valve runn141 Transmission - Rearend 1 02-04-2007 01:56 PM
Engine runs like krap after valve lash adj. HELP! Jag Daddy Engine 10 05-18-2004 02:37 PM
Adj valve quartet Engine 0 11-02-2003 06:40 PM
