American Racing Torq Thrust II center cap screw size? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2009, 10:06 PM
Last journal entry: 1955 Chevy Truck
This may sound crazy, but I can not find the screw size used to attach the center caps to the American Racing Torq Thrust wheels. These are the 5 allen head style screws that attach the center cap. I have tried a search in numberous places and have found them, but I simply would like to go down to the hardware store and see if I can purchase them. My wheels did not come with any screws, so I have no idea what size they are. Are they stainless or chrome? Are they specialized so that I have to buy them through American Racing, or can I go to Grainger or McMaster Carr to find them. Any help would be greatly appreciated!
Old 09-29-2009, 06:42 AM
screw size
the screw is 8/32. dont use allen heads there are so small there some times strip i used philip head the lent of the screw is 3/8 of a inch.
Old 09-29-2009, 08:12 AM
302 Z28's Avatar
You can buy the identical screws from McMaster Carr in stainless steel. You will not be able to find them in any hardware store. The actual screws that come with the wheels are soft and the allen head will strip out very easily. Order more than you need and you will never run out. McMaster Carr does not have a problem with small orders and ships super fast. Great business to support for all sorts of items.
Vince
Old 09-29-2009, 08:28 AM
302 Z28's Avatar
The ones I actually ordered were these, they are the harder 3-16 stainless steel and are a little more expensive than the 8-18 stainless steel and come in smaller packages. This is how many I have left after replacing the cheap OEM screws. First time I had my tires re-balanced I stripped out 8 of the cheap screws trying to get the center caps off.
Vince
Old 09-29-2009, 09:17 AM
Thanks alot for the info. That is exactly what I needed! We have a McMaster-Carr here in Kansas City that I will get them from. Do you use any anti-seize on them for the stainless to aluminum issue? Just curious.
Thanks
Old 09-29-2009, 09:23 AM
302 Z28's Avatar
Yes, just a small dab of anti seize is all you need. Your very fortunate to have a McMaster Carr so close.....I'm jealous.
Vince
Centerline center cap Question Mustangsaly Hotrodders' Lounge 18 03-26-2008 11:37 PM
Back up on the dyno. MK2TMR2 Hotrodders' Lounge 33 06-23-2005 01:47 AM
Tire size for torq thrust II's sicksixseven Suspension - Brakes - Steering 6 03-13-2005 06:55 PM
American Racing Torq-Thrust II 505 Series Wheels - Which Combo? nightrain_rod General Rodding Tech 4 08-17-2003 02:10 AM
WELD WHEEL SCREW ON CENTER CAP GOFIGURE2001 Hotrodders' Lounge 0 07-03-2002 07:46 AM
