Ammeter wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2004, 03:01 PM
Old Man Draggin'
Ammeter wiring
I need some advice. I just bought a'63 Impala SS. The car has a 3 gauge set but the ammeter is not hooked up. I cannot remember how to hook one up. I know you have to get the right wire and run it through the meter. This is a 327 300hp with stock wiring except it has HEI distributor. Any help is appreciated. Pete
Old 11-29-2004, 08:09 PM
MI2600's Avatar
Member# 3287
My '67 Service Manual shows a 10 ga line from the junction block behind the battery to the ammeter. Then another 10 ga line from the ammeter to the left terminal on the horn relay. They show fusible links in both lines, probably 14 ga.
This is probably pretty close to your '63.
Old 11-30-2004, 06:14 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Schematic CHECK IT
Kevin
Old 11-30-2004, 07:25 PM
Old Man Draggin'
Thanks, Kevin the schematic is good, but I dont understand what the "all other power drains" means. Pete
Old 12-26-2004, 12:42 AM
Old Man Draggin'
Here's an update fellows. My gauges are Autogage and after reading all the info recommending a voltmeter, I figured out that I could buy an individual voltmeter that could be put into my three gauge set in place of the ammeter. This simplified everything and worked out well.
Thanks for the imput.
