Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Amp gauge
Thread: Amp gauge
Old 04-25-2013, 04:44 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
Trouble with an amp gauge is that all the cars current must go through it to get a proper reading. That means taking a main wire through the amp gauge.....A volt meter just monitors the voltage, so a feed from almost anywhere will tell you your charging system is working....I would just install a voltmeter if I were you.
