Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Amp gauge
Thread: Amp gauge
Old 04-26-2013, 02:01 PM
ogre's Avatar
ogre ogre is offline
the 'Duracell Project'
i did a write up on how to change an amp meter to a volt gauge in a task force truck over on the 67-72 truck forum
i have a build thread over there look for post 36 67-72chevytrucks.com
i used the stock gauge face and inserted the guts from a 2'' volt gauge into the stock cluster
here the truk is off and voltage is zero, i installed the needle to be on the middle dot when the voltage is 14 volts
