Amp Hookup - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2006, 09:11 PM
Amp Hookup
Hi, I have a SUN-PRO amp gauge and I need help hooking it up. The car is a 64 chevy and has the old alt and voltage reg. I need to know what wires I need to put where. Any help??? Thanks alot. Don
Old 07-25-2006, 09:33 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
I don't think I have done one of those but it cant be to hard! Black is - negative. Red is + positive with DC. Are those the colors you have?
Old 07-26-2006, 03:50 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
A TRUE Amp gauge is always installed in series with the line..(battery) and the load (The fuse buss).
Locate the wire that supports the fuse buss, and separate it from it's source and place the gauge in series where the wires came apart...
ARE YOU sure you want to USE an AMP gauge???
A Volt meter is MUCH safer, and if you blow a shunt across the gauge, it will not leave you stranded without power..
It Does NOT have constant BATTERY potential across the meter 24 / 7 / 365...for you to drop tools on or catch your watchband on (burning it right off your arm) melting metal, or harness, or starting fires..
NEEDS only power and ground in PARALLEL to the load, with a low amp fuse (5 or so amps) ..and works as well as an amp meter once you get used to using one..
Just a Thought..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Correct Alt Amp gazrnr Electrical 2 09-18-2005 09:45 PM
100 AMP Service In Garage Help daveh Garage - Tools 9 02-27-2005 02:15 AM
Dangers of High Amp Output Ironman Introduce Yourself 4 12-06-2004 02:48 PM
NEED HELP! Amp is not getting power Meka Electrical 2 07-10-2004 06:15 PM
High Amp Alternator 84layinframe Electrical 3 04-25-2004 05:00 PM
