Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - amps, voltage and ?
Old 06-29-2012, 07:01 PM
sparkchaser sparkchaser is offline
Cold cranking amps is the max the battery will deliver at 0 degrees F for 30 seconds. Most battery manufacturers no longer list amp hours on the battery and instead list reserve capacity, which is the time in minutes the battery will supply 25 amps and still have a voltage above approximately 10.5 volts.
