angle grinder maintenence - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2009, 05:09 PM
Last journal entry: frame build
Go to your favorite home improvement place and get a tube of Worm Saw Grease. Throughly knead the tube. Take the angle drive cover off your 4" or other size angle grinder and fill about half way with the worm saw grease. Don't remove the original grease unless it has hardened or has cuttings in it. If it is removed, fill the cavities with chassis grease before adding the worm saw grease The new grease will mix with the old and will be thin enough to lube the upper bushing every time you lay it down. Replace cover and your done.
You'll be surprised at how much better it will work and how much cooler it will run.
Old 09-04-2009, 09:03 AM
dinger's Avatar
This is good info. Can you put this in the Wiki? That way it won't get lost in the pages.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
6" angle grinder kicked back ... and I took it right to the face lowROLLERchevy Hotrodders' Lounge 23 04-21-2008 04:24 PM
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 32 05-11-2007 07:22 PM
what pads/discs to use w/ angle grinder? taylorpontiac Garage - Tools 2 01-12-2006 04:04 PM
notching tubing benchracer1 General Rodding Tech 16 04-12-2005 11:02 PM
Removing paint with a angle grinder prd Body - Exterior 8 07-28-2004 05:07 PM
