Angle Grinder or Sawzall ?
Hi all
I bought an E350 with an 18 foot cube Van body and an 8 foot Lift Gate to use for picking up various projects..
It was the right price and came with a few problems that were easy to fix...except....
The Lift gate is fully operational, a rail style, 8 foot wide and about 36 inch deep platform. It is bowed in the middle and makes it tough to wheel dollies loaded with engine projects etc into the van....
I dont see any practical way to straighen it as is... so...the main platform is welded 2x 3 square steel with 1/4 inch diamond plate welded to the top. My plan was to cut away the platform itself leaving the side structural pieces and just fabricate a new platform between them....so I dont have to mess with any pivot points or brackets...essentially cut the old center portion of the lift gate platform away and build a new one....
Any of you metal fabricating gurus suggest which would be better to do the cutting / I have a 4 inch angle grinder and a pretty stout Milwaukee Sawzall....Have to cut a total of 36 inches each side... any thoughts ?
Thanks.. Mike B
