Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Angle Grinder or Sawzall ?
Old 07-09-2012, 04:13 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
Actually you will need both tools..cut the diamond plate with the cutoff blade in the grinder and then use a 14 tooth bi-metal blade to cut through the square tube to finish..
Good luck..
Anther thing to consider is see if any of your buds have a plasma cutter..
Sam
