Common problem ...
and a easy fix too ... KD tools makes this seal remover ... removes the seal easily without having to remove anything but the shift lever itself ... about 10 or 15 dollars NEW ... Mine was about 4 or 5 dollars new ... a long time ago ... Found this one ... on the BAY ... http://cgi.ebay.com/ebaymotors/GM-Tr...QQcmdZViewItem Cheap .... and it is NOT my auction nor do I know the guy ... just a heads up but the auction does give the KD part # for the tool ... #2393 ... so you can get one local if you so wish ... Deuce ... |
You are WELCOME ...
The seal is a common seal ... for all aluminum PG, Turbo 350's, Turbo 400's and even the 700R4's ... My GM dealer has them ... cheap ... Transmission shops too ... |
You will find the tool mentioned does not fit most aluminum power glide shift shaft seal..... different size shaft and shift linkage setup.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| Trans leak | jamn50 | Transmission - Rearend | 1 | 03-23-2005 06:44 PM |
| AOD into mustang | Stangman196700 | Transmission - Rearend | 3 | 12-16-2004 08:51 PM |
| Vacuum Leak Detector | rally4x4racer | General Rodding Tech | 1 | 02-11-2004 06:46 AM |
| 79 Trans Am T-top leak | RideDannyRide | Interior | 3 | 09-29-2003 04:45 PM |
| Fine Metal in Trans (NEW) | bigjoedo | Transmission - Rearend | 1 | 08-09-2003 01:23 PM |
