Annular booster carb on dual plane intake - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2013, 04:40 PM
I am having trouble understanding the intended application of annular boosters.
I grasp the general concept of better fuel atomization, better throttle response, low end torque perks and higher vacuum signals.
Why would Annular be better for single plane manifolds?
What are the cons of running Annular on a dual plane manifold?
Old 04-28-2013, 12:04 AM
Does anyone run annulars in a dual plane intake?
Old 04-28-2013, 07:42 AM
LATECH's Avatar
From what I understand about annulars they dont perform well through all rpm ranges, like on a street motor. I am no authority on annulars, seems to me they are a good setup for circle track. A dual plane isnt ideal either.
For the street you want the dual plane and a drop booster style. Remember I am no expert but If I remember Correctly.....
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
0trbo4myCHEVUICK (04-28-2013)
Old 04-28-2013, 08:05 AM
Banned
There are a wide variety if annular boosters and some work much better on the street and some don't. If you want the best carb then you need to call a great carb boutique and have them build you one. It's expensive though and IMO foolish when Efi is cheaper BUT for the best results go to the best carb shop.
Old 04-28-2013, 11:05 AM
I am having A company build me a 725cfm carb with vacuum secondaries and annular boosters. I am running a performer RPM dual plane intake.
Does the dual plane intake cause "rich" conditions with annulars?
The things I have read lead me to believe annulars would be well suited for a street engine. Although I would like to hear some application specific advice because I have found zero facts on annulars and dual planes, besides Holley listing "Annulars are designed for single plane manifolds" somewhere on their website.
Old 04-28-2013, 11:07 AM
I did not relize there are variations to Annular boosters, S'pose I need to check into what style im getting.
Old 04-28-2013, 06:15 PM
vinniekq2's Avatar
boosters are like jets,there are a lot to choose from.Most people dont bother because of the hassle to change them.I used an annular 830 on my 454,it worked great on both the performer and victor jr oval port.
The Following User Says Thank You to vinniekq2 For This Useful Post:
Old 04-28-2013, 08:02 PM
I reckon ill give it a shot. Im sure it will work out awsome..
Old 04-29-2013, 12:22 PM
Anybody else have experience running an annular booster carb in a truck with dual plane intake?
Intake swap: dual plane airgap to single plane ? y2k600f4 Engine 6 09-19-2009 06:11 AM
Carb gasket dual plane intake to 4 BBL D. Newland Engine 3 09-26-2008 05:36 PM
Intake Manifolds Dual plane Vs Single Plane chevy_power427 Engine 20 08-05-2008 05:00 AM
Single Plane Or Dual Plane intake? goalie Engine 9 01-16-2008 09:40 PM
single plane intake vs dual plane cuda66 Engine 5 03-04-2003 03:03 PM
