Anoter cam selection thread! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2008, 12:53 PM
Last wiki edit: Quadrajet
Wiki Edits: 7
Racing Motor - Cam selection
So here's another thread about selection for my camshaft. I am building a 283 for circletrack motor and am meant to be leaving the enginge stock as equipt from factory! Now obviously nobody does that unless you're really green The rule that I have to keep with is the 15" of vacume at 800 RPM. Other than that someone will have to do a tear down of the motor and then check grind numbers to check the camshaft.
Here are the two that I am looking at and then I have a few questions.
Comp Dual Energy 12-208-2 Summit Racing Link
Comp XTREME Energy 12-238-2 Summit Racing Link
I am already planning to use Rhoads lifters to help on the idle quality and vacume readings. Here are my questions:
What is your recomendation among those two camshafts? I have to run stock manifolds exaust (center dumps) and intake. I have unmodified 60cc chamberd GM heads and my 283 is not bored. Do you think the vacume will be alright?
The notes on both the camshafts say [2] Requires machining on cylinder heads. *** does that mean? could they be a little more ambiguious? What will need to be machined?
Old 03-13-2008, 11:07 PM
Wiki Edits: 7
No ideas? I usually get a near immediate response! I was hoping for some feedback since I need to start buying my parts!
Cam selection 400 sbc help gleveric Engine 12 11-16-2004 08:28 AM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
Cam Size / Carb Selection Relationship, Four Corner Idle rmhuizenga Engine 9 06-20-2003 08:54 AM
