another 10 bolt question! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2007, 07:30 PM
How fast is fast enough?
I'm putting another s10 (a '91 long bed) together and this one has a modded 2.8L (putting out about 190 hp) with a 5 speed and a 10 bolt. It is also lifted 2" and has 33" "all weather" tires.
I'm planning on swapping over to a 4.56 gear set (so I can use 5th gear again!) adn putting in a mini-spool while I have it apart since they don't make a full on racing spool for the newer 10 bolts. My question is weather or not I'll have to swap axles. I know running a sini spool on the street is not really a "smart" idea but niether is a lot of the things I do. Considering my fairly low power output and relatively tractionless tires (compared to slicks) should it hold up alright with stock axles?
Old 04-18-2007, 07:39 PM
larryblack's Avatar
Certified Lead Foot
You most likely have the 26 spline axles. If your spool is for 28 or 30 then you would definately need to swap axles.
I would highly recommend you get some after market axles. The power of the motor is not the issue, the spool and tire size will probably cause more grief than the engine.
Old 04-18-2007, 07:46 PM
alright- where a good place to buy some axles?
Old 04-18-2007, 07:49 PM
larryblack's Avatar
Certified Lead Foot
Check a hot rod mag for moser. I was quoted about 230 for a set for my 92.
Old 04-18-2007, 08:01 PM
I guess its looking like I'll be going through the whole thing then. And the spools available are either 26-spline or 28-spline... Atleast the only ones I can find.
Old 04-18-2007, 08:35 PM
larryblack's Avatar
Certified Lead Foot
I got a richmond rebuild kit from jegs. It was a good price. All gaskets, bearings and lots of shims. I also got my 4.10 gears from jegs too.
Brake lights switch oldsmo Electrical 4 10-19-2006 11:23 AM
F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt Mad Maggot Transmission - Rearend 8 02-17-2005 08:02 PM
10 bolt question JamesRS Transmission - Rearend 9 02-01-2005 08:52 AM
stupid 10 bolt question dustinh2988 Transmission - Rearend 3 01-25-2005 02:31 PM
10 bolt axle questions ChevelleGuy Transmission - Rearend 2 06-17-2004 12:08 PM
