Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - another 10 bolt question!
Old 04-18-2007, 07:39 PM
larryblack's Avatar
larryblack larryblack is offline
Certified Lead Foot
You most likely have the 26 spline axles. If your spool is for 28 or 30 then you would definately need to swap axles.
I would highly recommend you get some after market axles. The power of the motor is not the issue, the spool and tire size will probably cause more grief than the engine.
