Another 383 build
I just joined the site after searching through all the 383 builds and info
I am building my first 383 here is a list of parts. What do you guys think, and what kind of torque and horsepower can I expect?
350 block 2 bolt main 010 casting bored 30 over
ARP main studs
Scat cast crank
Moroso 23020 windage tray
Melling M55HV oil pump ARP pump stud
7 qt deep pan with pickup
Pro Comp 5.7 bushed 383 rods (clearanced)
Probe flat top forged pistons
Moroso 25050 Lifter Valley Baffle
Edelbrock performer RPM heads 64cc straight plug
1.5 ratio aluminum roller rockers
Stud girdle
.100 chromoly push rods
gear drive (noisy)
Comp Cams hydraulic roller XR288HR-10 Lift 0.520 int./0.540 exh. Duration at 050 inch Lift 236 int./242 exh.
Edelbrock performer RPM intake
APP bolts for heads and intake
The reciprocating assembly has been balanced
As for a carb I have a Holley 0-4779c 750 double pumper, but when I talked to the Holley tech they said that it's to big and to go with a 0-4778c a 700 double pumper.
