Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Another 383 build
Old 08-23-2009, 03:15 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by MUD CHILD
Thanks for the input, I will ditch the gear drive in favor of a good timing chain. Any suggestions as to which one to use?
Here's an example of a timing set I might use on a budget rebuild for a street motor. The crank sprocket is hardened, but the cam sprocket is not....
http://www.summitracing.com/parts/CLO-9-1100/
I might use this set if I were building a more performance-oriented motor. Both sprockets are hardened and the set is hand-matched at the factory....
http://www.summitracing.com/parts/CLO-9-3100/
If I were interested in changing the cam phasing to find the sweet spot cam-crank I might use a Hex-A-Just set like this...
http://www.summitracing.com/parts/CLO-9-3100A/
and a timing cover like this to allow easy access to the adjustment....
http://www.summitracing.com/parts/CLO-9-221/
