another 400sb help thread - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2008, 04:37 PM
pal pal is offline
hey guys, i need some advice on my 400 sb. i have a 1972 4 bolt (i know 2 bolt is better) this engine has a fairly fresh rebuild on it. i think the pistons are the old heavy TRW's, L3276 .030. they are deep dish. stock rods. i was going to use some small chamber double humps, but that deal never happened. a friend gave me a 69 327 i was going to use the heads off of. last night when i pulled them i found out they are 75 cc chambers, 1971 3973487 heads. they do not have the 2.02 valves in them. with a tape measure (crude) they measure between 1 15/16 and 2 inch. my problem is that this build is coming to an end and $$ is being spent on all the little stuff. if i use these 487 heads, is my engine going to be a real dog? my chassis wieght is 2200-2500 lbs., M-21, rear gear un-decided, 1 3/4"x18" primary tube, with 3 1/2" collectors, and a 4x2 intake with 94's built by the dickster over on the HAMB. i have not selected a cam at this point, and could use some help there as well. i like solids and would like to use one even knowing that this is a low RPM engine. i dont need a radical idle, but since it is a old school type hot rod, it still needs some of that hotrod sound. i dont want to use vortec's, because of my old vette covers and the intake i have, plus money. so will the heads i have work, or am i pissing up a rope? thanks, pal
Old 02-11-2008, 05:08 PM
King of my Man-cave.
Depending on whether or not you want to mill the heads, you will be around 9:1 compression. The Lunati solid 40155 cam will work OK for your solid sound and won't kill the torque. I'd use 1-5/8" headers if I were building it.
tom
Old 02-11-2008, 05:39 PM
pal pal is offline
thanks tom, the 9.1 will come with milling, or thats what you estimate it without milling? sounds better than i thought. i was thinking those pistons and 75 cc heads would give me low 8. something CR. i will look up the cam. one thing i did not mention was, this roadster is just a now and then take it out and raise a little hell, not a drag or street racer. pal
Old 02-12-2008, 09:31 AM
66sedanman's Avatar
Pal I'm showing 7.7 to 1 compression with 30 cc dish pistons factoring in at least .010 in the hole , 5.56 rods, 4.20 gasket, .039 crushed gasket ,75cc heads, and a stock 4.125 bore.
I always use a calculated program like this one:
http://kb-silvolite.com/calc.php?action=comp
If you went with some flat top pistons and a 3.75 rod it would give ya around 9.5 to 1 and a better squish than those factory slugs. and make sure ya drill the steam holes in any heads ya throw on the 400.
just my .02cents
Old 02-12-2008, 10:20 AM
You'll have to check the depth and diameter of the dish. If I figure a .135" dish and the valve reliefs, I get around 15cc, which gives 8.9:1. I figured a .020" deck height and 9cc for the head gasket and 76cc for the heads. Deck the heads .010"-.015" and you are at 9:1.
tom
Old 02-12-2008, 11:32 AM
pal pal is offline
if i remember right, the part number on thede pistons indicate a 25 or 26 cc dish. it was once figured to be 9.4-9.5:1 CR with 64cc heads. does this sound right? if so, and i use the 75cc heads the CR will be way down in the 8's. it sound as if its going to be a real dog.
Old 02-12-2008, 11:41 AM
If they are 26cc, mill the heads to 72cc (.030"), 0 deck the block and you will be at 8.8:1 or so.
Or get a piston more designed for what you want (with less dish).
tom
Old 02-12-2008, 12:16 PM
66sedanman's Avatar
I would keep the larger chamber heads and replace pistons and deck the block. I f you went with the speed pro flattops at 6cc for valve relief and 0 decked the block that would give you 10.27to1.
I correct my first post of 7 t0 1
i put in the wrong stroke. (DUH)
Im assuming you would go .030 on the bore to make a 406
heres 75cc heads with 26cc pistons and .020 on the deck your current set up---- 8.29:1
same set up with 64cc heads------------------------------ 9.07:1
same set up with milling the heads to 72cc----------------- 8.49:1
changing to flat top pistons and leaving the block at .020 deck with your current 75cc heads----9.84 to 1
changing to flatops and 0 decking the block with your current 75cc heads-------- 10.27 to 1
I think if money permits the last choice is what I would do, look on ebay or
at some speed shops online , pistons can be had at around $225 plus 100 for rings, and 5.7 scat rods are around 230. and then you will have a more reliable set up with alot more power and better quench.
Old 02-12-2008, 01:35 PM
pal pal is offline
okay that helps a lot. i will leave block as is, because its was re-built in the near past,and because of money at this time. what i am thinking is to mill the 75cc heads and run with the 8.49:1 CR. i will watch for some nice 64cc heads in the near future. how does that sound? now to have my cake and eat it to, what should i do for cam choice? as i have said, i want a solid. if i purchase a cam, lifters and springs suitable for my set up an future 64cc heads, can i get away with it for awhile on the 75cc heads? i rather not buy 2 cams. thanks, pal
Old 02-13-2008, 12:05 PM
pal pal is offline
this is all very helpfull information and i appreciate the time its taking to help me. last night i did a little checking, and have TRW L2376 .030 over pistons. also i am going to re-ring and bearing the engine. so i will be taking the block in to booil and check everthing. the pistons are 24cc dish and are .025 down in the cylinder. what should i do as far as decking the block? at the least it needs a clean-up. i quess what i am asking is if i deck the block and mill the heads down (how much) will my CR become decent? still have tight budget to work with, but i want it to be right when done. how does the idle sound on that lunati cam? thanks, pal
Old 02-13-2008, 02:00 PM
66sedanman's Avatar
I have read about guys having these pistons cut as flattops and then running 5.7 rods wich you can pick up super cheap. look here http://speedtalk.com/forum/viewtopic...3f7a7fc34d4b76
with that setup you have now 24cc dish and .025 in the hole youll have 8.35 to 1 with the 75cc heads
with just 0 decking youll have 8.72 to 1
with o decking and using 64 cc heads youd have 9.6 to 1
I would look into having the pistons cut down, just curious on the cost
Old 02-16-2008, 10:22 AM
pal pal is offline
there has been alot of very good advice given here. i decided not to work with the unknown. i tore the rest of the short block down and yes its a recent rebuild, but it shows signs of neglect and detionation. so i have it at the machine shop now, and will know what i have or dont have to work with this coming week. i met with 3 shops and really felt comfortable with the one i decided on. after a full cleaning and inspection, decisions can be made. they do recomend a "true deck", i guess thats a zero deck? also they claim that my heads can be angle cut for whatever cc i want. they build and race there own stuff plus have a engine dyno. there thoughts on this engine if all checks out are; true deck the block, angle mill the 75cc heads to 64cc, and use flat top pistons. i will see how everything checks out before macking any decisions about a cam. thanks, pal
Old 02-16-2008, 12:59 PM
66sedanman's Avatar
Yea listen to F-Bird ^^^^^^^^^^^^^^^^^^^^^^^^
Cant run a flat top in a 406 with 64 cc heads on pump gas. 11.5to1 like he said .
I would have them clean up you heads to like 75cc have them zero deck the block and with the flat tops you will be at 10.2 to 1 running on super unleaded.
