another 406 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2010, 12:48 AM
another 406
hi ive read quite a few diffrent versions of 406s that people have posted and i had a few questions about building my own so any help would be great and thx in advance.
heres what i have
forged crank
and a set of protopline 235/72cc chambers
10 degree moly retainers, #614-16 10 degree valve locks, #98643 .750 lift Congo roller springs, stainless one-piece chrome stem racing valves, guide plates, 3/8 or 7/16 ARP studs, #SC531 VTO seals.
forged mahle 11 cc dome pistons
i was wondering what cam should i run
am i calculating correct to 13.1 compression
could i run this on e-85
thx again
Old 06-20-2010, 02:11 AM
techinspector1's Avatar
Wiki Edits: 326
Will require E85 or race gas. Will need long cam to prevent making so much cylinder pressure that you can't keep head gaskets in the motor, in the area of 260 degrees @ 0.050" tappet lift, solid flat tappet or solid roller tappet. Will make power 4000 to 7500, so will need some good parts in the motor. Figured your static compression ratio at 12.73:1. Alternative might be shorter cam with more street-friendly cam timing with copper head gaskets and o-rings. Dynamic compression ratio would be outa-sight.
There must be some roundy-round guys on here that can give you a better answer than I have. Those guys deal with 12.73 and alcohol every Saturday night.
Old 06-20-2010, 09:55 AM
ericnova72's Avatar
More for Less Racer
You haven't given us enough info on the engine, or the vehicleand weight, and transmission/rear gearing, or the intended us to help you much as far as picking a cam or any other part. Fill in the blanks.
Old 06-20-2010, 02:32 PM
going into a 3rd generation camaro. i have a 400 turbo tranny built for up to 1000 hp (dont plan on goin that high but its beter to have more than enough just in case) 9 in rear end build by autoweld specificaly for the camaro
i have a rotating asymb. and everything is forged and h-beam rods
was looking at e-85 as a cheaper alternative to race gas
Old 06-21-2010, 02:11 PM
anything else that you need to know?
Old 06-21-2010, 04:29 PM
ericnova72's Avatar
More for Less Racer
How high do you want to rev it?? What rpm torque peak?? What converter stall?? What rear gear?? 1/4 or 1/8 mile Drag?? Street use at all?? Tire size??
The more info the better.
Old 06-21-2010, 08:48 PM
alright. 4:11 gear ratio. going to be running some slicks havent picked any up yet but its the plan. will see street part of the time like a sunday cruizer not everyday. looking to build about 600 hp rev no more than 7000 but i doubt it'll see 7000 too long
Old 06-21-2010, 09:46 PM
ericnova72's Avatar
More for Less Racer
I'm assuming you want a solid roller as that is what you said the heads are set-up for. Something like 260-264 intake duration, 264-268 exhaust duration @ ,050" (maintain a 4 split between intake and exhaust), .650" In-.630" Ex lift, 108 lobe seperation, installed at 105 intake centerline(3 advanced).
Old 06-22-2010, 11:04 PM
do you think that this combo should get me around the 600 hp range?
Old 06-23-2010, 01:07 AM
ericnova72's Avatar
More for Less Racer
I would expect it to or be very close.
list your 400 or 406 sbc combo's here,,, what works the best for you tiresmoke55 Engine 16 08-12-2010 08:26 PM
still having 406 trouble tiresmoke55 Engine 26 11-23-2009 11:58 AM
406 sbc questions tiresmoke55 Engine 13 04-26-2007 10:50 AM
406 build up,,, need to have more HP tiresmoke55 Engine 34 09-01-2006 10:21 PM
timing on a built 406 Blob Engine 8 06-04-2004 07:27 PM
