another 700 question, different vehicle - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2006, 10:54 PM
Jmark's Avatar
Have a question on my wifes '86 Caprice. 305, feedback quadrajet, assuming its a 700 trans. She's compaining of sluggish acceleration again. Trans shifts fine in all gears. My questions are:
Do the early 700's lockup in third gear and fourth? (this one seems to go into LU in third)
If so, can I unplug the third gear switch on the VB so it only locks in fourth without hurting anything?
Can it be run in the "D" position in town (not in "OD") without hurting anything?
I guess what i'm trying to do is keep the rpm's up some at low speeds so its a little more driveable instead of being in OD and lockup at 35mph. Kinda muttly!
Thanks.
Mark
Old 06-21-2006, 11:38 PM
Malibu73's Avatar
'68 Chevelle Malibu Sedan
Yeah man, I keep my 700R4 in 3rd everywhere in town. On the highway, I don't shift into 4th gear until I'm at 65mph or faster. Because I have a 2.73 rear end right now, so the RPM go too low for my liking.
Leave it in D in town, it won't hurt a thing, and yes mine locks up in 3rd and 4th although I don't know about unplugging the gear switch.
Old 06-22-2006, 05:36 PM
Jmark's Avatar
"Bump".....anyone else?
Old 06-22-2006, 07:31 PM
jakeshoe's Avatar
I would just downshift to 3rd in town. The converter lockup affects the cooling circuit quite a bit. The trans will probably produce more heat in town with the converter working more from stop to stop.
383 stroker 73monte Engine 13 05-11-2016 12:17 PM
supercharger.... 73monte Engine 16 07-24-2010 11:27 AM
700 clearance question Jmark Transmission - Rearend 3 05-24-2006 10:17 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 02:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 11:25 AM
