Another 700r4 lockup question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2011, 02:42 PM
I have a 700r4 in my 4x4. As with most I'm trying to get my lockup wiring within spec for my needs.
After looking through posts on this site and others I think I have a decent understanding of how I should wire this up, but I have a few questions.
From what I read it appears that I just need to keep my hot wire from my brake switch to terminal A and I can jumper terminals B & D together to bypass the computer and get automatic lockup when in 4th gear.
My question is by doing this can I disconnect the vacuum switch at the firewall and is this even a good idea.
Also, the one part I don't understand is how to manual engage the torque converter in 2nd or 3rd.
What I do know is that the current stock setup has the lockup engaged in 2, 3, and 4th gears and I have pretty violent 2nd to 1st shift at about 5mph. Also there is a tendency for the converter to engage and disengage back and fourth when i'm driving a lower speeds in town which is really annoying.
Old 07-06-2011, 09:37 PM
SSedan64's Avatar
Also, the one part I don't understand is how to manual engage the torque converter in 2nd or 3rd. [/B]
The Vacuum switch is to prevent Lockup at anything but light throttle. This prevents TCC/TorqueConverterClutch damage. You could install an adjustable Vacuum switch to tune the Lockup point. This would prevent the TCC cycling.
Old 07-07-2011, 11:21 AM
Thanks for the info about the vacuum switch.....after doing a little more reading I think I've got the wiring stuff figured out.
1988 700r4 lockup question Crazz Transmission - Rearend 4 04-10-2007 07:54 PM
700R4 3rd & 4th lockup chrisape Transmission - Rearend 6 11-14-2006 06:25 AM
700r4 lockup runn141 Transmission - Rearend 3 09-06-2006 06:40 AM
700r4 or 350 lockup oldschool Transmission - Rearend 2 01-09-2006 04:25 PM
700R4 Lockup question AngliaBob Transmission - Rearend 2 05-08-2005 11:55 AM
