Another 700r4 problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2008, 04:52 PM
I have a 1987 chevy fullsize blazer with a 700r4 I was having problems with it not shifting into gear unless I took my foot off the gas. I got it fix the guy I got it from didnt have it in the bracket all the way . Now it seems to be a little sluggish when it shifts to 3rd like its a manual tranny and its lugging down . I drive it in drive only cause the guy unhooked the lock up for the convertor and I'll be getting it fixed soon. Also when I'm slowing down to come to a stop it acts like it is searching for what gear its to be in and starts bucking alittle it goes from 3rd to 2nd back to 3rd into 2nd into 1st.Any help would be grateful ........
Old 07-08-2008, 07:12 AM
SSedan64's Avatar
Souds like the TV cable needs adjusting. Check this Info.
http://purplesagetradingpost.com/sum...o/700R4p1.html
Old 07-08-2008, 12:37 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
This could be the Torque Converter Clutch Solenoid stuck closed.
Experiment some with the TV cable adjustments. A few clicks in or out should make a difference.
Old 07-08-2008, 03:08 PM
I noticed mine wont down shift from second to first at wot throttle and I tried to tightened the cable and still wont do I need to back it off alittle .
89 Suburban 700R4 Problem JoeB Transmission - Rearend 13 11-06-2006 04:56 PM
700r4 TV Cable Problem jack71 Transmission - Rearend 7 10-25-2006 09:05 PM
700R4 Tranny Shift Problem riesman20 Transmission - Rearend 2 10-13-2006 11:21 PM
700r4 problem bmoon Transmission - Rearend 5 04-20-2004 01:01 PM
700r4 shifting problem 89chevstepside Transmission - Rearend 0 05-08-2002 03:10 PM
