another big block option - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2010, 04:39 PM
ss396si's Avatar
Would you guys agree if i were to buy donor car or truck w/ a 454 for cheap. Pull it out, slap on heads, cam, intake and distrubetor and heads in my garage. My car 69 chevelle th400, moser 12 bolt w/true-trac and 33 spline axles.
Old 04-30-2010, 11:07 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
I'm confused, what are you asking about? what do you want to know?
Rich
Old 04-30-2010, 01:18 PM
ss396si's Avatar
I just would like to know if its a wise move to pull a big block from a another car or truck and to install it in my chevelle. It sounds cost effective.
Old 04-30-2010, 01:30 PM
fourspeedwagon's Avatar
6 reps of 12oz curls
Last journal entry: 65 SS Project
Check out the engine well- compression test, etc. and if it looks good, I recommend doing it. As long as your not building a racer, it's way cheaper short term to swap a good runner in than to build a new one. I just did it with a 1 ton truck 454 for my chevelle. 500 for the truck, a couple hundred into headers, oil pan, mounts, etc, with plenty of parts to resell and try to recoup some funds. Hopefully I'll only be into the engine $300-500 total after that. Good luck
Old 04-30-2010, 02:47 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Yup, that's what I did.
Around here, a 454 sitting on the ground in a wrecking yard costs $1000.00.
"It was running when we pulled it out a couple of years ago." Yikes.
I bought a 1979 C20 "3+3" Camper Special that I could not only hear running, but drive home ... for $500. It was on propane, and was not in the best state of tune. The shifts were a litlle late and hard, but no slippage at all.
After I got it home, I did a compression test (135 - 145) and a basic tuneup. The rubber vacuum hose to the trans was old and broken, so I replaced that, too.
I jumped back in it and took it for a drive around the block. Not bad! The old girl would even break those big 16" tires loose without too much trouble!
I thought about just cleaning it up and using it just the way it was ... but quickly changed my mind. I wanted a "performance" engine, not just a stump-puller. The rest, as thet say, is history.
PS. I had the TH400 trans redone as well. The fellow that did it said that it still looked pretty good for 100,000+ miles, if it was original.
So yeah ... $500.00 for "known good" and complete, running, "cores" was a bargain, IMHO.
Old 05-01-2010, 05:15 AM
Guy Hiltz's Avatar
If it were me,that motor would be coming apart for at least an overhaul.The heads would probably need a complete going over as well,new guides,seals,springs etc....
Guy
Big block chevy into a 91 S-10?? 12second6 General Rodding Tech 11 04-28-2009 06:43 PM
Ford Big block 4 spd bellhousing bigblocktorino Transmission - Rearend 3 10-05-2006 03:56 AM
hv big block pump for small block roy383ci Engine 9 05-24-2006 06:52 AM
big block or small block ford? stangfiend Engine 3 12-10-2002 09:55 AM
Big Block/Small Block - Ford BigBlockBabe Engine 12 11-10-2002 04:01 PM
