Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Another blower question
Old 01-22-2013, 04:26 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by 496CHEVY3100 View Post
have already purchaced Comp Cam Blower Cam
I'll bet your Comp "blower cam" is cut on a 114 LSA. Read this from Blower Drive Service...110 works best for gasoline...114 works best for ALCOHOL...
"Choosing the proper camshaft would be the most important requirement for a blower motor. An improper cam will cause a variety of problems that can easily be avoided by following a few simple guidelines. Hydraulic cams are recommended if you intend to drive the vehicle frequently, requiring little or no maintenance, and the maximum engine RPM's are kept around 6500 or lower. Roller rocker arms are recommended. Flat tappet and roller cams are recommended for high performance applications especially where the engine will see high RPM's. Exact camshaft specifications vary depending on the performance level you wish to attain. BDS offers different types or stages of cam grinds specifically made for blower motors. Refer to camshaft specs listed in tech info for BDS' individual engine camshaft specifications and their intended uses.
If you wish to purchase your cam from one of the many fine camshaft manufacturers, we suggest using our camshaft specs as a guidline. Extremely high lift and long duration cams are recommended for high RPM, high performance racing only.
The lobe center of the cam will play an important role in determining the performance characteristics of an engine. Wide lobe centers (112 to 114 degrees etc.) will create higher cylinder pressure providing more horsepower with cooler burning fuel such as alcohol and methanol. We have found 110 lobe centers to produce the best overall power on gasoline.
Whatever cam you choose, make sure that it will operate and perform properly in the RPM range required for your application."
I don't know what it is that makes you guys jump up and buy the cam as one of the first items. Cam and torque converter should be the last 2 items bought, after you've finished the drivetrain and everything else.
The Following 2 Users Say Thank You to techinspector1 For This Useful Post:
496CHEVY3100 (01-23-2013), vinniekq2 (01-23-2013)
