Another boating adventure - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2011, 08:08 PM
383Eliminator's Avatar
So yesterday I went out it lake Martinez in Yuma After some tuning and rejetting the carbs. I came out of the no wake zone and headed north towards the sand bar. I eased up on the throttle and it sounded pretty good with no problems. I got a little excited floored it and after about 2 seconds it's backfired real bad and killed the motor.. I quickly looked for a hole in the motor but everything looked normal.. I got towed to the nearest sand bar and started troubleshooting. I found there was back and forth play on the rotor. After pulling distributer I found 3 and a half teeth broke off the distributer gear. Today I pulled the timing cover to make sure there was no damage to the timing chain and that the bolts in the cam were still tight. I also checked the lash in a my rockers to make sure I didn't have a bent push rod or valve. I'm pretty sure it was run if way to lean and had too much timing. I jetted the carbs up 5 sizes to 73 on the primary and up 2 sizes to 78 on the secondaries. I had the timing locked at 32 degrees and backed it off to 28 degrees and still locked out. I took it back out today to make sure everything was ok.. I took it real easy for a while to make sure I don't Granade the motor. Then we made a couple WOT passes and monitored everything real close. The boat ran solid 80 mph with 2 people in the boat and 84 and some change with only myself in the boat.. Not bad for a small block in a 21 foot boat..
Old 10-26-2011, 07:03 PM
Richiehd's Avatar
JS-70
I d be concerned about why those teeth got broke and where they ended up.. Roller Cam? and you say you went 5 sizes to 72? What carb you running.? please more info
Old 10-27-2011, 09:20 PM
Where to start.. I'm pretty sure the distributer gear broke because it leaned out and the motor back fired. After the backfire the motor died completely.. Pretty buzzar if u ask me? The carburetors are Holley boost referenced 600's (2).. Ate first the plugs were pretty good but I was only making about 2-3 lbs of boost at 10.5% underdriven. I Did some research and discovered that have a small bore 6-71 and need to spin it faster to get more boost.. I then swapped the pullies to 10.5 over driven. Before the carbs were 68 primary and 76 secondaries out of the box.. As a precaution I jetted up to 76 and 78.. After running this for another day out I pulled the plugs and it seemed like they were a really warm plug. NGK R5671A-7. But they were still pretty dark on the porcilen. So I but the R5671A-9 in to see how it ran and jetted back down to the 68 and 76.. I went back out just to test and tune and that's when it happened.. Maybe 5 min on the water and it backfired and died.. It was ok if I slowly eased up on the throttle but when I was aggressive then it backfired.. Yes it is a solid roller cam.. Also timing was locked out at 32 which I learned the hard way was too much for 8-10 lbs of boost with pump gas.. It's a little hard because I have been told that jet boat resist detonation a little more because the engine temp stays way down 150-160 range at all times.. And I have aluminum heads.. As far as the pieces to the distributer gear I'm getting ready to yank the motor for the winter because I have a few upgrades I would like to do and I can drop the pan and pull them out.. They looked like they broke clean off.. I figured pieces that big either did damage on the say down or it didn't.. After getting into the oil pan they are harmless.. It stripped 3 and a half teeth off so the distributer would not engage the cam at all.. That's what leads me to believe that they broke clean off.. I did manage to get 2 pieces out with one of the extendable magnets but the other pieces fell all the way down..
This is going to be an adventure!!! roadster27 Introduce Yourself 2 10-09-2006 02:01 PM
68 GTX adventure dinger Hotrodders' Lounge 1 05-05-2006 01:30 PM
Rental car adventure pigjamelectric Hotrodders' Lounge 2 01-18-2006 05:36 PM
a adventure from the past spinn Hotrodders' Lounge 0 04-25-2005 11:48 PM
Adventure or just crazy? Iroc'o Hotrodders' Lounge 2 02-19-2003 06:05 PM
