Another Brake fitting question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2008, 06:31 PM
I just got my Tight fit master cylinder fittings from Total Performance. They have 4 AN fittings for output. I thought I would be smart and order two 12 of brake line with the proper AN fittings. I was going to cut of the AN fitting on one end and replace it with a standard 45 double flare male fitting.
The problem is the two 12 stick of line is Stainless and I cannot flair them.
Now I guess I need to find a 4 AN female to standard female.
Any suggestions? This brake stuff just confuses me.
Shawn
Santee, SC
Old 03-14-2008, 07:43 AM
Holder350's Avatar
Auto Parts Professional
take it to a place that makes hydrolic hoses, they should have the machine to produce the 45* double flare on the other end.
If they dont they may be able to fix you up with an adapter.
Old 03-14-2008, 08:32 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Shawn,
You should not double flair SS line, it will harden
& split, unless you use annealed SS, + SS uses 37* flairs. There is a ton of info on SS lines here, just
click on the search button on the top of the page & type in SS brake lines.
Good luck,
Rich
Old 03-14-2008, 02:48 PM
Holder350's Avatar
37* flares are only used on AN (stands for Army Navy) and JIC fittings.
If you have flaring tool like this
You "can" do a single flare with one of these....I have done it, but its not easy. But I haven't hurt the tool or myself yet.
However sense I have access to a tube and hose machine now I usually flare stainless on 45* double flared.
I have had single flares crack but have yet to have trouble out of a double flare.
WARNING to double flare ss tube you MUST have a machine or take it to someone how has a machine and the knowledge to do it.
Old 03-14-2008, 07:44 PM
I do have a piece like that.
I tried to do a single flair with it last night. It stripped down the little
teeth enough that it will not hold my standard metal tubing anymore.
The tube slip when I try to do the first phase of the double flair.
Shawn
Santee, SC
Old 03-14-2008, 08:09 PM
Holder350's Avatar
yup...that'll happen with some of the cheaper one (and some of the good ones) plus its almost impossible to produce a double flare with one of those tools in SS.
Your best bet is going to a shop that makes hydralic lines and let them use the machine to do it.
Old 03-15-2008, 08:35 AM
powerrodsmike's Avatar
Wiki Edits: 161
As was stated before, the SS tube MUST be annealed to double flare @45*, it does not matter if you use a machine or not.
Call the company that sold you the tube and ask if it is soft annealed or regular stainless tube. If it chewed up your flareing tool trying to single flare it, it is probably un annealed.
If it is regular stainless tube, you must use 37* flares and fittings. JIC will interchange with A-N when using hard lines.
There are many adapter fittings available from Earls, Russel, Goodridge, and Aeroquip.
Later, mikey
BE different....ACT normal.
Old 03-15-2008, 12:02 PM
Holder350's Avatar
Yeah when we do SS on the tube and hose machine we have to heat it with a torch then produce the flare then heat till its HOT HOT then let it cool.
all it really does is lets the crystals in the metal to reform in the shape of the flare.
Like I said to get it done right take it to someone who makes their living making lines.
Once you get it to a 45* flare it'll connect to all of your existing lines.
Drum Brake Question EazyDuzIt102 Suspension - Brakes - Steering 25 12-08-2010 08:11 PM
Brake hose question for 74 camaro garretthes Suspension - Brakes - Steering 13 08-02-2007 09:26 AM
brake question marlene kit car Suspension - Brakes - Steering 8 09-24-2006 12:20 AM
brake master cyl question! 67 Deuce 4 Me Suspension - Brakes - Steering 3 08-08-2006 12:47 AM
brake question Tissue Suspension - Brakes - Steering 5 03-22-2004 05:28 PM
