Another Broken Starter Nose - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2005, 04:52 PM
GoneNova/406's Avatar
i have two 406's that have the same problem.i just built another 406 with less c.r. for gas price's and i broke the starter nose off the other day.i never got to that extreme with the first one but it was bad.you align either one and they are good for a short time usually and then we're off again.the first one had 185-195 lbs. of cranking compression but thats not it.it has new starter bolts and i have 1/2 a dozen starters that all do it.i tried to hook up the small bracket on the back of the starter but the stater shield and headers are in the way.someone said GM starters don't do it but i can't believe that.anyone have any rational ideas?
Old 05-26-2005, 05:21 PM
my alter ego
I don't know how rational this may be but is the timing overly advanced causing a kickback? Does the flexplate look like it has excessive runout (out of round) when the engine is running(ie bent crankshaft or bad flexplate)?
Old 05-27-2005, 01:12 AM
i drove the other motor daily and the ignition was advanced a good deal but not more than it could take since it ran great.the other flexplate was stock as was the crank but in good shape.the new motor is just that.new.i worked with it today and got it working for now and pretty good too.we'll see how long it last.the flex plate is new and h.d. and breaking that nose did booger the edge of a couple of teeth but not bad.i just wish that i could get to that bolt hole on the block on the back side of the starter.i did how ever have the bendix out to line it up as well as i could but how long will it last?
Old 05-27-2005, 01:28 AM
willys36@aol.com's Avatar
Wiki Edits: 21
If you don't use the bracket on the tail end of the starter, you will likely be breaking more noses. That's why they design the brackets in the first place!
Old 05-27-2005, 01:41 AM
yes.easy for you to say.think i wouldnt use it if i could?
Old 05-27-2005, 02:53 AM
Pony's Avatar
There are several different brackets to choose from. I used a factory one that was 1/2" x 1/2" angle iron , hooked to the top stud and a tapped hole on a boss about 2" below the head. It hugged the block and cleared the starter shield and headers easily. Without some kind of support you will probably keep on busting noses. Good luck.
Old 05-27-2005, 05:55 AM
I was having the same problem with my 10 to 1 c.r. 406 and used the 1/2 x 1/2 angle iron bracket on mine and it seems to have cured the problem. It clears my headers with no problem.
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
I determined that my recent broken starter was due to kickback. When I went to a hotter ignition it begain to rear its head. I set my cranking timing back and all is good. If you have an MSD, they make a plug in module for cranking timing retard.
Chris
Old 05-27-2005, 05:58 AM
i'm not some simpleton that doesn't know which end of the wrench to use.if it were that simple i wouldn't be talking to you.its in a van which you know that the motor sits inside a dog house just big enough for the engine.its not some huge enine bay.the dog house comes off inside the van then you have to somehow get behind the headers and the starter shield is slightly in the way also.if thats not enough its below the floor board.if it were that simple i wouldn't be here talking to you.and you can't get to it at all from the bottom.thats why i'm asking for other ideas.the only other thing i can think of is to take back out and fab another bracket and go up around the head somewhere to find a bolt to hook the bracket to.last nite i got it in and aligned so it is starting for the time being better than it has since before the last 406.so just maybe i'm on the right track
Chevy 350 cracked starter mounting hole w pics skiprec Engine 14 11-11-2011 07:47 AM
Ever break the starter nose?? TurboS10 Engine 29 05-26-2005 04:38 PM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 04:52 PM
Broken ear where starter bolts in Circus Engine 15 02-06-2004 12:13 PM
Carry on from other Starter POST dollybud Electrical 0 09-26-2003 06:48 PM
