another calculator found :) - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2005, 10:39 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
drag calc
estimates 1/4 mile and 1/8 mile info.
matt
Old 03-20-2005, 11:00 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
i checked it out
Its fairly accurate.
Old 03-21-2005, 07:00 AM
Silentlion_69's Avatar
Duck Tape & WD 40
Last journal entry: No more Vehicle
if its fairly acurate then my old truck ( 85 GMC) Would have ran about a 16 second 1/4 mile. Yeah I think your right about it sounding fairly accurate. My truck took forever to get up to speed
Old 03-21-2005, 07:31 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Says my Willys is a 10.56 car! Not likely!!
Old 03-21-2005, 09:50 AM
Last journal entry: The floor going in
It say rpm at the finish line if i new that i would no my 1/4 mile time anyway
or am i doing it wrong?
cheers stuart
Old 03-21-2005, 10:10 AM
Wiki Edits: 21
RPM has a bearing on time but there are more (acceleration) parameters than that. You for sure know your top speed if you know RPM but it doesn't tell how you got there so time could vary quite a bit.
Old 03-21-2005, 11:34 AM
bracketeer's Avatar
489 Lemans
I know all my numbers
I know all my numbers; gears, tire height, rpm, weight, et, and mph. It was only off by 2/10ths on my car.
Old 03-22-2005, 01:46 PM
Wiki Edits: 7
neat little debate started here. I don't know my car's rpm at the end of the 1/4, either. If I did, I'd prolly know what it'd run, thus rendering the calculator useless other than something to mess around with.
Well, I'd have to run my GrandAm, since the Javelin has non-functioning brakes.
Old 02-21-2006, 10:36 AM
zipfactor's Avatar
Last journal entry: Just starting
Na, you could use the javelin, just tie a parachute to the back of it
