another cam help question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2010, 03:46 PM
Ok so i just wiped an intake lobe on my cam in my truck so id like some opinions on picking out a new one.
-1984 c10 pickup 4200 lbs, automatic 3000 stall, 4.10s
-350 sbc patriot heads 58cc chambers, 200cc runners, 10.5:1
Im looking for something with more torque to pull my out of the hole. It is a street strip truck and ran a best time of 14.5 @ 99 (maybe that could be due to a partially wiped lobe?). The cam that came out of it was a comp xe284h... too big of a cam for my setup in my opinion but im looking for something more torque. Does anyone have any good suggestions for a heavy truck like mine? Trying to shave some time off of that 1/4 mile. Thanks
Old 10-27-2010, 04:04 PM
If I ran a taller gear i would loose mph top end. That isky cam is also alot like the previous cam i was running, power doesnt come on until after 2500 rpms. Im looking to bring that down a bit and keep my 410s. Keep in mind im only running a 3 speed and i do drive to the track/around town so a taller gear isnt an option.
Old 10-27-2010, 06:38 PM
I ran a 28 inch street tire. As for the timing i was running very light mechanical springs, full mechanical advance was in at 2000 rpms. When im up on the converter to launch my timing should have all been in. 18 degrees at idle, 36 degrees with mechanical advance, and 44 degrees total including vacuum.
Cam Lift question Please Fastest65 Engine 25 08-27-2010 04:21 PM
Comp Cam Question crystalbluevib Engine 5 03-03-2010 08:25 PM
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 06:12 PM
cam and quadjet question derek32303 Engine 8 06-12-2007 05:59 PM
cam question beetle9 Engine 1 12-06-2002 11:23 AM
