another cam question.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2010, 05:42 PM
Jason7504's Avatar
I was already settled on getting a comp XR280R solid roller cam for my 468 big block with 10:1 cr, ported 781 heads(2.19/1.88), forged bottom end, 8-850cfm holly carb, RPM intake, 2" headers with 3" exhaust,th350 with 3000 stall, 3.42-3.73 rear gears with 26" tall tires. But now I'm not sure if the dynamic cr will be low enough for pump gas with the XR280R cam and my 10:1 scr. I was thinking of going with the howards 121313-12 instead since it will have a broader power band and better idle with the 112lsa vs. comp's 110. my dcr wit the comp should be around 7.9 and the howards should drop it to 7.5 which i heard is better for BBC's on pump gas w/ iron heads. Do you guys agree? and what kind of power difference can i expect with the Howards over the Comp?
comp xr280r:
http://www.compcams.com/Cam_Specs/Ca...?csid=499&sb=2
howards:
http://www.summitracing.com/parts/HRS-121313-12/
Old 06-17-2010, 09:42 PM
Jason7504's Avatar
bump......
Old 06-18-2010, 01:25 PM
Jason7504's Avatar
anyone?....
Comp Cam Question crystalbluevib Engine 5 03-03-2010 07:25 PM
Howards Cams Greg T Engine 21 10-04-2009 12:28 PM
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 05:12 PM
cam and quadjet question derek32303 Engine 8 06-12-2007 04:59 PM
cam question beetle9 Engine 1 12-06-2002 10:23 AM
