It definetly must be very flat and very black as there is not enough reflection to see what it really looks like. But I bet it looks great. How about some shots of it outside in the light. |
Now that is a lot better.
Looks like it turned out pretty good. I think the JD black is the way to go if you want really cheap and good looking. If you get tired of it you can repaint your car and not be out very much. |
like you said, I can still repair , repaint or spot repair areas, and not be out very much money, already scratched one fender, and I have a lot of work left to do. But , at least now I can kinda get an idea of what it will look like !It's better than looking at primer or rust everyday.
I try to get at least, a little something done on it each day. Don't always work the way thou..What does help is, my 'shop' is this old horse barn I fixed up, just for working on 'my stuff' , and not useing the house garage. I can just leave everything lay on the floor, lock the door, start right back in tommorrow !
I'm sorry Brian, I answered your post yesterday, but I guess I didn't get it entered....It's called 'Blitz Black' by John Deere. For more info, just read back a couple of posts or look it up in the 'search' feature at the top of the page .
extra parts
I need some help here :when I took this engine apart, I didn't notice where all this stuff went cause I wasn't going to use it . BUT, now I need to know where this bracket goes ? It's above the power steering pump ( I think ), also a bracket that the trottle springs are attached to, as indicated by the yellow wire nut.............thanks
....................It's a ' 85 318
I decided the bracket is correct, and was used for an air pump, which is no longer there, because the exhaust manifolds have the air passages. So, this brings up a new question; can I just block off the fitting on the manifold that the air line was hooked to ?
| chop 1932 ford pick up | wizard1932 | Body - Exterior | 3 | 05-18-2009 08:28 PM |
| TOP CHOP | Bill Corum | Body - Exterior | 3 | 08-10-2008 10:29 AM |
| To Chop or not to Chop | 1931 steve | Body - Exterior | 23 | 03-20-2008 10:23 AM |
| top chop, and channelling advice? | rlackey | Body - Exterior | 8 | 08-19-2005 02:25 AM |
| How much for a nice paint job? | Elevinpointsixtoone | Body - Exterior | 18 | 12-21-2004 06:13 PM |
