another chop job - Page 11 - Hot Rod Forum : Hotrodders Bulletin Board
  #151 (permalink)
Old 11-18-2007, 10:02 AM
I need a radiator...was thinking of taking the measurements to the junkyard... then remembered...tranny cooler. Is there something special I need to consider when finding the correct rad ? I do have a external oil cooler on my parts shelfs from 'something' that measures about 8x18. If I used that, would it be too much to cool, if I also added the AC cond ? OR am I just thinking too hard and just go get any rad that fits ?
  #152 (permalink)
Old 11-18-2007, 11:30 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Before you get too excited check out the tru-kool radiators from speedway motors..and just run an accessory cooler for the trans..those can be bigger than the stock ones any way..that is what I have decided to do with mine..
Sam
  #153 (permalink)
Old 11-18-2007, 05:10 PM
I'm suprised at the price of the rad you referred to, ( under $200), have to see wgat the junkyard will, plus, IF the used one needs a new core or something..................... I may have to consider using some 'new' parts yet!.........thanks
  #154 (permalink)
Old 11-21-2007, 09:59 AM
'48 Dodge & '85 318
Installing inner front fenders to check the clearance around this engine , and of course it don't fit any more , so will require some modifying... For example..power steering hose... I can make the original hose from the '85 work, by twisting it and tying it in a knot, but looks like 'crap' . Question : can I find a factory hose from something, that will fit this application ? I don't want to get one custom made, as then if it breaks down on the road somewhere , can't just go into a parts store and get one.
  #155 (permalink)
Old 11-21-2007, 11:07 AM
Wiki Edits: 3
Actually it is not all that much to have one made or both for that matter and of all the things that can fail the steering pump hoses are very low on the list..
Sam
  #156 (permalink)
Old 11-21-2007, 05:55 PM
I hate it when you guys come up with simple and logical answers,but, I guess you never know til you ask ...............thanks
  #157 (permalink)
Old 11-21-2007, 09:31 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Get two made and you won't have any worries.
  #158 (permalink)
Old 11-21-2007, 11:52 PM
Chopt 48's Avatar
The other option is to go to a "real" parts house like a NAPA and ask to see the power steering hose book. There is usually a photo section that will show you the different pressure hoses. It might take a bit of hunting to find one that is correct but you should be able to come up with one that comes close.
I do have to agree that a custom hose will work just fine and the chances of failure are slim.
most pressure hoses just have a slow seepage if they leak unless they have something rub them or get against something hot.
Now I need to go back and see what your are using for a pump and steering box.
  #159 (permalink)
Old 11-22-2007, 02:37 PM
I am using everything I can from a '85 5th Ave. The 318 and tranny, rear axle ,front suspension (volare style) electric seats and windows ( I hope) Power steering gear and pump, also, . had to modify pump barckets to move it in closer to block to clear the steering gear box. Today modifying the inner fenders to clear alternator on the right, steering sector on the left.
  #160 (permalink)
Old 11-24-2007, 12:17 PM
inner fenders
[IMG][/IMG] [IMG][/IMG] here's a couple pictures of the inner fenders cut to fit... they are a little dark, but I think you can see it , may have to download and enlarge them to see any better...
  #161 (permalink)
Old 12-01-2007, 11:21 AM
Moving to the rear of the car now, putting the rear axle in from the '85 ,using the springs and mounts from the '48,. the '48 had a stablizer (panhard bar) from the frame to the axle which I'm using. Also it had a swaybar under the front. As the '85 with the volare style suspension has a swaybar included, I'd like to add this 'extra' bar to the rear axle. Is there anything special I need to know sintalling this ? Or maybe some help making some brackets ? How to mount this to the floor or trunk floor ? or Frame ?
  #162 (permalink)
Old 12-10-2007, 11:50 AM
Back to the front; making brackets to install radiator and fan. Using radiator from ' Ford Explorer and electric fan from a Buick : They fit pretty good, only the water outlets are opposite. New Question ............what can I make the waterpipe (to go across the motor) out of ? Also the bottom one will have to go behind the damper pulley. Conduit ? Exhaust pipe ?[IMG][/IMG] [IMG][/IMG]
  #163 (permalink)
Old 01-10-2008, 11:49 AM
  #164 (permalink)
Old 01-10-2008, 11:59 AM
I lost a picture in here somewhere , but anyway, now I got the the rad, from the Ford Explorer, condenser from the '85 5th Ave, and a oil cooler for tranny all mounted and connected . Question now is.... if the four blade Buick eclectric fan is big enough ?? Any thoughts ??
  #165 (permalink)
Old 01-11-2008, 02:02 PM
wiring diagram for "85 Chry 5th Ave
Today I'm working with the dash and it's componets. New problem : I need to install the wiper motor from the '85 into this '48. First I need to run the motor to watch it linkage travel. I need the wiring diagram for the motor, so I can 'hotwire' it to get it run. Where can I get the diagrams?............thanks
chop 1932 ford pick up wizard1932 Body - Exterior 3 05-18-2009 08:28 PM
TOP CHOP Bill Corum Body - Exterior 3 08-10-2008 10:29 AM
To Chop or not to Chop 1931 steve Body - Exterior 23 03-20-2008 10:23 AM
top chop, and channelling advice? rlackey Body - Exterior 8 08-19-2005 02:25 AM
How much for a nice paint job? Elevinpointsixtoone Body - Exterior 18 12-21-2004 06:13 PM
