another chop job - Page 12 - Hot Rod Forum : Hotrodders Bulletin Board
  #166 (permalink)
Old 01-22-2008, 10:40 AM
gas tank and hangers today, moving tank over to allow more room for duels. repairing the tank itself, inside and out. Question ; will epoxy primer ( Nason by Dupont) work to line and seal the inside of the tank? I have some left over from the body work, the tank already has had the "ospho'' treatment inside. Will the epoxy primer bond to the treated inside of the tank ?
  #167 (permalink)
Old 02-03-2008, 12:10 PM
tail lites
ums/t9/knighthawk_01/000_0589.jpg[/IMG]
  #168 (permalink)
Old 02-03-2008, 12:12 PM
  #169 (permalink)
Old 02-03-2008, 12:14 PM
  #170 (permalink)
Old 02-03-2008, 12:18 PM
tail lights
tail lites are in : original lenses, bumper pushed in and down, no cost involved !!
  #171 (permalink)
Old 02-08-2008, 09:47 PM
dash
here's picture of the ol' rusty dash, after a little polish and paint !
  #172 (permalink)
Old 02-18-2008, 04:35 PM
just bounceing around here , working on different areas, putting off buying some componets (finances kinda tight) , back to the front fenders......frenched headlite,.... is there a headlite adjuster screw that can be adjusted from the rear ? thru the back of the bucket ?............thanks
  #173 (permalink)
Old 02-23-2008, 04:47 PM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
Excellent job on the chop!
Aside: I hate photobucket. A lot of the image links posted earlier in the thread now come up with "Page Not Found".
  #174 (permalink)
Old 02-25-2008, 09:22 AM
grouch : thanks for the encouragement, sorry about the missing photos, I should have the originals somewhere if there is something tyou want to see. It has been a very intresting project, never done this before, a few things I've redone over, didn't turn out like I was hoping ....I lot more brain work than I expected ! Alot more to come !
  #175 (permalink)
Old 03-10-2008, 01:45 PM
electric windows
here's how I put electric windows from a '85 5th Ave into my "48 Dodge.........basically, just swap the lift arms, and install the gear and motro where ever it works the best ....
  #176 (permalink)
Old 03-10-2008, 01:48 PM
  #177 (permalink)
Old 03-10-2008, 10:05 PM
grouch's Avatar
Wiki Edits: 2
Hope you do something to those raw edges of the cut -- you could amputate something with those.
  #178 (permalink)
Old 05-08-2008, 08:42 AM
up date on the chop
brakes are hooked up, steering is done, started on the wiring.... installing the harness from the '85 parts car leaving out the 'lean burn' crap . It's working good for connecting the electric seats and windows, but pain in ***** to connect to the old dash ! Am using the '85 318 wiith a dist and modual from 69 to 72 , but having a hard time finding the 'pigtail' harness to connect the two . Any suggestions ?
  #179 (permalink)
Old 05-18-2008, 04:57 PM
wiring location ???
so, I'm putting the battery in the trunk , have to run a battery cable forward. Also want to re-route the harness that usually goes along the door sills(seats and taillites ). I'd like to put them on or along the tranny hump, but then I'd have to splice and make them longer.... BUT... I've been told put them UNDER the car and run them in or along the frame rail. Any suggestions ??? Road salt would not be an issue, just maybe water and mud ????????
  #180 (permalink)
Old 05-19-2008, 05:31 AM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
You should keep the battery cables out of the car for sure.Water and dirt won't hurt them.
As for other wiring under the carpet, should be okay as long as you don't use oversized fuses.
chop 1932 ford pick up wizard1932 Body - Exterior 3 05-18-2009 08:28 PM
TOP CHOP Bill Corum Body - Exterior 3 08-10-2008 10:29 AM
To Chop or not to Chop 1931 steve Body - Exterior 23 03-20-2008 10:23 AM
top chop, and channelling advice? rlackey Body - Exterior 8 08-19-2005 02:25 AM
How much for a nice paint job? Elevinpointsixtoone Body - Exterior 18 12-21-2004 06:13 PM
