another chop job - Page 19 - Hot Rod Forum : Hotrodders Bulletin Board
  #271 (permalink)
Old 07-01-2009, 09:15 PM
found the brake problem... the brake pad was worn unevenly, one end was wore down 1/8''more thanthe other end, and when the caliper piston comes outward under pressure hitting the uneven pad, ***** the piston and locks it up. Then after a short while after pressure is released somes times frees up, other times stays tight ....after installing new hubs/rotors, calipers and pads, and a road test, all is fine !,,,.........now..on to the suspension........
  #272 (permalink)
Old 07-05-2009, 10:16 AM
thinkin'
when I first 'lowered' the car, I raised the rear spring schackles about 7'', by reshaping the the rear frame at the shackle mount. ( should be some pics somewhere in this thread ), figureing the axle (and wheels) would be raised 3 1/2 ''.....well that part was correct, it did lower the car, and retain all the original suspension. Problem : not enough suspension or travel clearance. Ais shocks helped, but made it too stiff. I only way to solve this ( I thought) is to section the frame rail for more bumper clearance and raise the floor pan over the drive line. As this part of the car was already done, I decided it would be easier just to lenghten the rear shackles by about 2'' , and it should raise the car enough. After modifiying the shackles, (longer) they won't clear the sheet metal behind the shakles, more changes there, also now thw longer shackle won't clear the bumper brackets, more changes there, maybe it will effect the shock travel, and maybe the sway bar mount..... then of course 1/2 way through all this, I ran out of cutting gas..........never is as easy as it looks!!!!!
  #273 (permalink)
Old 07-07-2009, 09:08 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Glad to hear you got your brake problem fixed. As far as your rear suspension I always found it amazing that one little change would affect so many other things. Good luck with your changes.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
  #274 (permalink)
Old 07-16-2009, 12:08 AM
good news; the suspension changes really helped, got a new carb...Carter 2bl from '69 Fury vintage, runs great ! At least it dii for a while, took it out for a test run today and to show off how good it was , Shut it down about 6 miles from home, wouldn't restart, had to tow it home. No spark ! I got the ECU modual and breakerless dist from a '72 Ply vintage, changed control unit, coil, still no spark. I heard now the the pickup unit in the dist goes bad ! Can't get a new dist til Fri (lifetime warrenty).............has to be at a car show Sat !!!! So, is it really worth it to use this electronic ignition stuff ????????? I'm thinking if I had regular points in it, it would be on the road already !!!!!!!!!not too happy right now, thinking of ripping it out, putting in the old stuff.................any suggestions ????/
  #275 (permalink)
Old 07-19-2009, 08:11 AM
went to a car show yesterday, put on about 100 miles, car ran great, the ride was pretty good, no breakdowns. BUT the speedometer quit working , checked it out last night I think it's just a dirty speed cup in the head itself ( I hope). Next issue is the steering....just doesn't feel right no freeplay , maybe too tight.. Have to find the correct factory method to adjust the sector.... I know with power steering it's different proceedure ?????????
  #276 (permalink)
Old 08-01-2009, 12:39 PM
still getting all the bugs out from using all these used parts ( still , total cost is about $4000 ) now the electric wipers, I was going to convert it over to the '85 (donor car) system, but I don't think there is enough room under the dash . So, as ling as the 6 volt motor appears to be usable, I think I'll just convert it to 12 volts using the proper resistor. Problem ; I don't know what size resistor,or where to get one, so I'm going to post this question in the ' electrical' section.................see what happens
  #277 (permalink)
Old 08-10-2009, 08:53 AM
I was advised when I started this project, not to use 'used' parts. Well I used 'used' parts, and lots of them. Sure, I 've had some problems from useing these 'used' parts, and eventually they have been replaced with new parts , BUT I went for a nother short ride the other day, got home., glanced at the temp gauge.... about 250 degrees !! The ' brand new temp/heat controller for the electric fan quit working !!!!!!! Luckily I had a manual back up power supply for the fan ! Sooooooooo, is it really nesseccary to build with all new parts ???? I don't think so !!!!!
  #278 (permalink)
Old 10-22-2009, 10:55 AM
I need a volunteer to post some pictures for me.... I can just barely send E-mail, I need someone to post them on this thread for me after I E-mail them to them .......I have some pics of how I installed my flush electric antenna, then of my headliner (another story )
  #279 (permalink)
Old 10-26-2009, 01:52 PM
electric antenna
maybe...[IMG]antenna[/IMG] [IMG]antenna[/IMG]
  #280 (permalink)
Old 10-27-2009, 09:30 AM
The End !
  #281 (permalink)
Old 02-02-2010, 11:49 AM
how to install a flush mounted electric antenna.....at least this is how I did it.........
Last edited by knighthawk; 02-03-2010 at 09:18 AM. Reason: lost my train of thought !
  #282 (permalink)
Old 02-03-2010, 09:15 AM
...let me try this...
  #283 (permalink)
Old 02-04-2010, 10:33 AM
new window 'fuzzies' IMG]http://i156.photobucket ,' baling wire' staples..
  #284 (permalink)
Old 02-04-2010, 10:42 AM
cheap and easy door panels cardboard pattern.. a little padding.....staple the fabricfinished product
  #285 (permalink)
Old 02-04-2010, 10:48 AM
while I,m here....this is the headliner I put in....very tough to do without any helpers !
chop 1932 ford pick up wizard1932 Body - Exterior 3 05-18-2009 08:28 PM
TOP CHOP Bill Corum Body - Exterior 3 08-10-2008 10:29 AM
To Chop or not to Chop 1931 steve Body - Exterior 23 03-20-2008 10:23 AM
top chop, and channelling advice? rlackey Body - Exterior 8 08-19-2005 02:25 AM
How much for a nice paint job? Elevinpointsixtoone Body - Exterior 18 12-21-2004 06:13 PM
