re: another chop job
Great job,i knew you could do it. I told you in the in the start of this post that the rear window was not going to cause you a problem. You did a great job with it.
guess that means, I gotta bring down the steering column , brake booster ,pedal hangers, seat, and the dash ! ( upstairs in the barn ) I sure wish I made this shop bigger !..................thanks ''chevy'' for the incouragement >
progress
speaking of progress, I set the seats in , to find the center for the steering and brake pedal..Where I'd like to put the pedal, it will not line up with where the booster will fit, cause of the column. Where the booster fastens to the master cylinder will have to be a few inches higher than where it was originally ,. Question : Instead of messing with the pedal arm ( too make it longer, and mess up the ratio ) should I re- do the linkage to the master cylinder ?
disregard the last post, cause I think if I recess the the booster in to the firewall, it'll be pretty close...........All this makes me think, you guys with the 20's bodys must have less room to work with than me !
If that doesn't work you could always use a Kugel Komponents reverse mount 90 degree under dash unit:
http://www.kugelkomponents.com/produ...akesystem.html |
I like the idea of the reverse mount, but how would you ever fill it ? I'm afraid one like that is not in the budget..........anyway, I just cut the firewall last night ............................thanks again , "Brew"
axle clearance
next area of concern ; since I have raised the rear spring shackles, it has moved the axle closer to the body. Right now I have about 4 '' clearance from the axle to the bumpers, and also the bumper on the differental.. How do I determin how much clearance I need ?
This is not a very "scientific" as I don't know how stiff your rear springs are. But perhaps it will you help out by bringing this post back to the top and other members with more experience and knowledge will see it.
Place enough weight in the car to approximate what you may be carrying in it (passengers, dog, tolls, etc.). Then bounce on the back bumper. I told you it was very "scientific".
Lots of 4" LED stand alone accessory tail lights for trailers and big trucks around but I don't know of any 3". I think it is time to get your tape measure out and attend a rod run and try to find some 3" tail lights that LED tail light reproductions are made for. Rodworx sells repro LED tail lights. Here is a link:
http://www.rodworx.com/products.php?scatid=17 |
Try flipflopled.com then may have them..they do have quite a few different things..
Sam
led lites
thanks guys, both sites are really good . I think it's what I'm looking for.Now, I thought I wanted to french the tail lites, like the headlites are , but if the car is shaved , decked, and flat black, may be the tail lites shouldn't be frenched, might be too plain or too smooth ???? What do you guys thinkl ? Does anyone have a picture of a car with a smoothed trunk AND frenched tail lites ?
| chop 1932 ford pick up | wizard1932 | Body - Exterior | 3 | 05-18-2009 08:28 PM |
| TOP CHOP | Bill Corum | Body - Exterior | 3 | 08-10-2008 10:29 AM |
| To Chop or not to Chop | 1931 steve | Body - Exterior | 23 | 03-20-2008 10:23 AM |
| top chop, and channelling advice? | rlackey | Body - Exterior | 8 | 08-19-2005 02:25 AM |
| How much for a nice paint job? | Elevinpointsixtoone | Body - Exterior | 18 | 12-21-2004 06:13 PM |
