another chop job - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 06-22-2007, 07:49 AM
O K , guys, I'm smoothing and filling the body right now, what or how do i do the the shaved door handles ? With out going electric ! Some kind of flush or recessed handle, AND using thre same door latches !
  #77 (permalink)
Old 06-22-2007, 09:06 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Back in the day - late 50's - a couple of guys I knew about apparently ran manual choke cables from the opening mechanism through the door and pillar and mounted then in the fender wells. One guy even retained one stock door lock key in the door.
Here is a couple of links on installing newer recessed door handles in older cars. They will give you some ideas you can play with.
http://www.hotrod.com/projectbuild/1...nt/index1.html
http://www.rodandcustommagazine.com/howto/55343/
  #78 (permalink)
Old 06-22-2007, 11:10 AM
Metal Twister's Avatar
Change is Opportunity!
Last journal entry: ( Chop Um-Up ) 1947 Plymouth Sedan Chop
Originally Posted by dinger
How far from Fallbrook is your shop, I see you're in the San Diego area. I just left there today, had a couple of food safety audits down that way. Dan
Actually we are in Spring Valley, Ca. (San Diego county). We are real close to the Hwy.94 & 125 connector. About 50 miles south of Fallbrook to answer your question.
  #79 (permalink)
Old 06-22-2007, 11:16 AM
One cool way of doing it is to run the cable straight down thru the door post and floor. Attatch it to a paddle peddle located under the car, simply slide your toes under the running board or rocker pannel and lift the peddle to release the door latch. Some strong door poppers will help with the effect.
  #80 (permalink)
Old 06-23-2007, 08:07 AM
thanks again guys, , intresting referrals, the coe in there looks just like mine !
  #81 (permalink)
Old 06-23-2007, 09:39 AM
home brew's Avatar
Thought I would give you some more to think about - as if you don't have enough already!
  #82 (permalink)
Old 06-23-2007, 10:38 AM
Ok! lets see it, Maybe we need a COE thread to insure we dont hyjack! In fact I will do it right now.
  #83 (permalink)
Old 06-23-2007, 08:43 PM
The feller with the custom camaro on here with the fighter jet theme has a good setup for this
Shane
  #84 (permalink)
Old 07-03-2007, 08:46 AM
I am cleaning and filling the front fenders and hood, getting ready for first paint (primer ) now thinking..... I will need to make a filler strip or front roll pan, so what is the accepted or legal hieght for the front bumper ?
  #85 (permalink)
Old 07-03-2007, 12:28 PM
home brew's Avatar
For legal height check with your DOT. Accepted height - above the scrub line. As I don't know the length of the body in front of the front wheels I can't even give you a ball park figure. Just remember that you have to go down and over the gutters of the road to get into parking lots, etc. If you can figure out what that slope is and use some trigonometry (always wondered when you would use it didn't you) you will be able to figure out how low you can go. Or you could just mount casters under the bumper.
  #86 (permalink)
Old 07-03-2007, 08:31 PM
thanks 'brew' again.......why didn't those math teachers give an example like this , maybe it would have gotten my attention !
  #87 (permalink)
Old 07-03-2007, 10:36 PM
Chopt 48's Avatar
Home Brew nailed it. The first time out with a freshly chromed bumper I got hung up going out of a grocery store parking lot in Bountiful Utah. And no that one wasn't quite above the scrub line.
Figure what roads you will do 90% of your driving on and go from there.
  #88 (permalink)
Old 07-30-2007, 08:27 PM
currant pictures
O K , Guys ! I need a volunteer to post some picture here for me. I have four pictures of the ''chop job'' in primer, but , can not post them ! Any offers ?......................thanks .
  #89 (permalink)
Old 07-30-2007, 10:40 PM
If you still need help PM me. I want to see that Thang!!!
  #90 (permalink)
Old 07-31-2007, 08:46 AM
home brew's Avatar
Here's those pics of the chop in primer. I didn't have to resize these. Looking great!!! What's next?
ID:	23040   Click image for larger version
ID:	23041   Click image for larger version
ID:	23042   Click image for larger version
chop 1932 ford pick up wizard1932 Body - Exterior 3 05-18-2009 08:28 PM
TOP CHOP Bill Corum Body - Exterior 3 08-10-2008 10:29 AM
To Chop or not to Chop 1931 steve Body - Exterior 23 03-20-2008 10:23 AM
top chop, and channelling advice? rlackey Body - Exterior 8 08-19-2005 02:25 AM
How much for a nice paint job? Elevinpointsixtoone Body - Exterior 18 12-21-2004 06:13 PM
