Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - another chop job
  #254 (permalink)
Old 04-18-2009, 09:25 AM
knighthawk knighthawk is offline
computor working today.... took the '48 on it's 'road test' yesterday... after dark, which wasn't too smart, lites started flickering, going off and on, engines dies , 1/2 mile away from home ...... luckily I had a spare battery in the trunk, used to jump iit earlier.......... any way found out later it was loose battery cables ! And also th ignition switch needed to be adjusted, as I had nothing on the acc side . Now, once again , everything appears to be working....... except for that right front camber adjustment ( car pulls bad to the left ).....that may have to wiait till for an alingment shop................
