electrical issues worked out. Decided to run a few changes of 'cheep' oil thru the engine first, cause I don't waqnt to run a strong cleaner and knock a lot of stuff loose all at once.. But, I don't think it's that bad anyway........Took it for a 2nd road test yesterday, everything was perfect ....except for the steering..... I think something is bent in the suspension,cause it pulls pretty hard to the left. I guess it's true what they say, never use any used parts when you build your car.....I just assumed the front clip was good from the other car.....Oh Well......... just means an alignment shop will be on the schedual.........
